64 Lower A-arm removal, could it be any harder....
Once you have the rear bolt out of the control arm, fold the arm under the car next to oil pan, this will allow the rear of the control arm to drop and clear cross member. Slide arm off front pivot bolt. You may need to persuade it a little. Replace the arm the same way, but, because new bushings will make it a tighter fit it may take just a bit more persuading to reinstall. I just did mine a couple of months ago.
Hope this helps,
Norm
