09-04-2004, 04:46 AM   #1 (permalink)
loverboy4604
alternator and ignition upgrade questions
hello all.. working on my 63 1/2 500XL. originally a 352 car with a 3 speed on the tree... now a 429/c6 car and i have several questions about alternator and ignition upgrades.
I am using the first wiring diagram at this link http://www.galaxieclub.com/alternator-conversion.html
on this diagram it shows connecting the 2 wires from your thru firewall connection in to the system.
Im useing a factory ford alternator and voltage reg for the 429 it has in it...
CAN YOU splice int the factory harness and eliminate the wires for the generator and the regulator and its wiring all together???? or must you connect the wires in the factory harness to keep the circuit open/closed??
2nd i am using a duraspark II ignition easy to install and hooks up easy(i think)....
http://home.cfl.rr.com/fatrichard/duraspark/eec.htm is the site for info on the duraspark im useing.
it is a box with the blue tab and its electronic distibutor. Has coil and distributor on one plug set and 2 wires on 2nd plug set for hook up to the keyed ignition, but which way is easiest to connect these 2 wires into the system???
from what i read in a chiltons on the ignition (outta my 80's bronco book) the wiring is easy hook up a hot wire and these 2 switched/keyed wires and thats it..
hope you can help me i wanna hear what this beast will sound like with them big cubes and mad dog headers....
thanks much
<font size=-1>[ This Message was edited by: loverboy4604 on 9/4/04 4:59pm ]</font>
loverboy4604 is offline   Reply With Quote
09-13-2004, 02:46 AM   #2 (permalink)
loverboy4604
hey got it all figured out and she fired today... was easy just follow the directions at the links to the letter and they work...
man she sounds nice now all i gotta do is get the little stuff all hooked up hehe
brake lights are a good thing to have right?
<font size=-1>[ This Message was edited by: loverboy4604 on 9/13/04 1:48pm ]</font>
09-13-2004, 09:33 AM   #3 (permalink)
adgdghr123
Glad to hear you got it working. Hae any pics?
Oh, and yes, brake lights are a good thing! [img]/phpBB/images/smiles/icon_spongebob.gif[/img]
adgdghr123 is offline   Reply With Quote
