10-23-2004, 10:20 PM   #1 (permalink)
junkyardjeff
Rear disc brakes on a 65 galaxie
Since I am going to put 77-9 t-bird front discs on my 65 I am thinking about putting discs on the rear too,is there anyone running rear discs on their galaxies. I know mid 70s lincolns had them but the bolt pattern is bigger and there was a granada sized lincoln that did too but those rearends are expensive if they can be found so is there any reasonably priced kits out there.
10-23-2004, 11:15 PM   #2 (permalink)
F15Falcon
The Granada/Versailles is too narrow, the big Lincoln is too wide. You can do a cheap Stock Car style disc kit, but it requires welding, and you will not have a parking brake. I have put discs on the back of all kinds of cars, and the rear discs are not very much of an improvement, if at all over good re-done drums. Unless you are going to do some road racing, or if you do alot of mountain road driving, I would go with the 12" Lincoln front brakes with a booster, and rebuild the rear drums. I have installed the big GM caliper with the 12" rotors on a few Galaxies, and it does stop. The GM caliper has a bigger piston than the T-bird/Torino stuff.
10-23-2004, 11:26 PM   #3 (permalink)
etp20
i have a mustang and ford magazine that says 84 thru 88 lincoln mark 8's rear disc go on older 9 inch rears easily, u might wanna try that
etp20 is offline   Reply With Quote
10-24-2004, 12:39 AM   #4 (permalink)
tbirdchick
F15,
This is kind of a general brake question since you've done a lot of disc brake swaps. In your opinion, which front disc setup do you consider more efficient ...the T-Bird spindles equipped with the 12" '74-up Galaxie rotors or your own setup with the GM calipers that you showed us a few months back? I know that you've considered marketing yours as a kit and I'm not asking you to give away your setup. But I can build something similar and am just wondering which way to go. As you know, I'm planning on doing some corner carvin' with my '64.
Thanks,
Jan
tbirdchick is offline   Reply With Quote
10-24-2004, 12:58 AM   #5 (permalink)
tbirdchick
I think you mean Lincoln Mark VII as the Mark VIII didn't come out until '93....[img]/phpBB/images/smiles/icon_smile.gif[/img] I'm with F15 as I don't consider factory front and rear discs enough of an improvment over a front disc-rear drum setup to offset the extra work of installing rear discs on a Galaxie. I own both a '93 Crown Vic and an '88 Lincoln Mark VII with rear discs and neither stop perceptibly better than my '79 T-Bird with drums on the back. I've hammered the T-Bird pretty hard through the turns and I can't 'feel' any brake fade in the back, either.
Just my .02 worth,
Jan
10-24-2004, 01:04 AM   #6 (permalink)
F15Falcon
I have done it both ways with the GM calipers, meaning GM calipers with the stock '60-'64 Galaxie spindles and stock car rotors and hats and a fabbed caliper bracket, and GM calipers using the T-bird style spindle with the 12" Ford rotors and my own fabbed brackets. Either way I like the GM caliper because it is a floating design. I would do the latter style as it would save you some $, because you can find the 12" rotors in the junkyard with some luck.
10-24-2004, 01:29 AM   #7 (permalink)
dkbeam
I am currently working on a 65 and putting rear disc's from the lincoln mark VII. I have owned cars with both rear disc and rear drums and can say without a dought that the rear disc brake cars did stop considerably better than the drum cars. For the mark VII swap, here is a link to a guy who sells the brakets($100) and has some info on what cars to get the parts from. If you use the Mark VII stuff you get the benefit of having a parking brake. the kit is a bolt on and uses factory (FORD) parts and shares the 5X4.5" bolt pattern. You may have to cut and paste for the link to work.
http://www.ultrastang.com/Ultrainfo.asp?Page_ID=11
dkbeam is offline   Reply With Quote
10-24-2004, 11:56 AM   #8 (permalink)
tbirdchick
Thanks, F15. Using the GM caliper with the 12" Ford rotor is an option I hadn't thought about.
Jan
