01-20-2005, 06:17 PM   #11 (permalink)
tonys10sec306
NEED OPINIONS: should I rebuild my 289 or go with a 351w
I am 302 man So i would go with a 302
01-20-2005, 10:34 PM   #12 (permalink)
Dogface
I would hold off until you have the room/knowledge to do 75% of all the work yourself. Been there, lost money...but learned a lot.
Dogface is offline   Reply With Quote
01-21-2005, 05:13 PM   #13 (permalink)
MarauderMan
The 351W is a layup, no question.
Has a lot of extra performance you can actually use.
IMHO, the best thing to do is see what SVO/FRPP has in their catalog. I think they still list a very inexpensive, 8.5:1 351W with a 4V intake and iron heads that is technically the "marine" long block assembly.
It is to a Ford what the Goodwrench 350 is to GM cars and trucks. Solid, bulletproof and cheap.
It's about 250 hp, give or take, and all you do is screw on the Holley, get your accessories and go. IIRC, it also has the old "GT" / "PI" roller cam, which makes good power and pulls plenty of idle vacuum. For the record, that's as good or better than the SAE net HP for a 390 4V.
My memory may be playing tricks on me, but I remember the price being surprisingly good -- around $2250 all in with a warranty. The only thing you will want to do to go with this (and you'd have to do it rebuilding the 289) is to get a different trans.
The bellhousing pattern changed for '65 on the automatics from five bolts to six, I think. So you would need to round up a trans, probably a C-4 or an AOD. There is a wealth of knowlege here for these swaps.
Small block C-6's are expensive, hard to find, and eat hp's; the FMX / Cruise-O-Matic might hook up easier but it is harder to get parts for, heavier and really not much for performance although some folks swear by them, even on this board.
Good luck, sounds like a cool car.
MarauderMan is offline   Reply With Quote
01-21-2005, 06:58 PM   #14 (permalink)
MarauderMan
Well, the memory's not completely gone, just needs a tuneup.
Go to the FRPP site; they have a couple of 351s. Don't know who your local guy is, but, if you can get the motor in, a factory Crate engine is the way to go for a cruiser mill.
http://www.fordracingparts.com/parts...tKeyField=5679
There are two regular-joe 351 iron head motors; the 2V and 4V. Looks like the only big difference between 'em is the intake.
$2600 list at the Ford dealer for the 240 hp; $2895 for the 260 hp. You should be able to knock some off of that price, maybe a lot depending on your connections.
