05-06-2005, 09:42 PM   #1 (permalink)
dadurweird
FX Cruise-O-Matic
My 1966 Galaxie was delivered yesterday and looking things over, I compaired info from the ID plate and found my car has an FX Cruise-O-Matic behind the 289-2v engine.
A look at the trans and it is a pan fill model, certainly not a C-4, as there is no servo housing on the passenger side.
Just wondering, can anyone tell me about this trans? I suspect this trans is a weaker one than a C-4. Years ago, I had a 1966 Ford Custom with a 240 6 cylinder that had a C-4 behind it.
Thanx in advance for your comments.
Frank from Deeeetroit
dadurweird is offline   Reply With Quote
05-06-2005, 10:37 PM   #2 (permalink)
unforgiven
FX Cruise-O-Matic
I can tell you it is hard to find someone who can rebuild it correctly. When they work they shift nicely not much for hot rod purposes.
unforgiven is offline   Reply With Quote
05-07-2005, 08:15 AM   #3 (permalink)
KULTULZ
FX Cruise-O-Matic
-BROADER PERFORMANCE-
Having a FOM-COM-FMX is not a death sentence. It is a much tougher design than is given credit for. All earlier designs can be upgraded with service parts from the later FMX (67/ ). This trans was used into the eighties.
05-07-2005, 11:37 AM   #4 (permalink)
dadurweird
FX Cruise-O-Matic
Thanx for the replies, guys.
Is my FX the same length as a C-4? Will I need a different x-member and driveshaft if I swap out the FX for a C-4?
thanx
Frank
05-23-2005, 03:53 PM   #5 (permalink)
MarkP
FX Cruise-O-Matic
In '66-'67 Ford made a trans called the "MX". I've never heard of the "FX" in Galaxies before (but, that's just me...). The MX is VERY strong, has an 11" band for 1-R gears. It often was equipped with higher-speed-stall torque convertors for that "jetaway" takeoff performance. These torque convertors 'lock' at 1500 RPM instead of the usual 1100 RPM. It makes for a real quick, effortless feeling when driving, but at 55 MPH (2.75 rear) it gets worse gas mileage than at 65 MPH because the convertor locks at 58 MPH!
MarkP is offline   Reply With Quote
05-23-2005, 04:41 PM   #6 (permalink)
Chooch65
FX Cruise-O-Matic
Let's see. I had a Cruise-O rebuilt locally here and the guy did a good job. I bought another Galaxie with a Cruise-O that shifts fine. For a cruiser it is very smooth. For hot roddinf or racing I would go another way![img]/phpBB/images/smiles/icon_smile.gif[/img]
Chooch65 is offline   Reply With Quote
05-23-2005, 07:03 PM   #7 (permalink)
dadurweird
FX Cruise-O-Matic
My trans is for sure an FX, definately not a C-4. The door code says my FX was made in Kansas. Cannot find any hi-perf suggestions for the FX, going to swap to a C-4 when the time comes anyways.
Just curious to know if my FX is the same case length as a C-4? Food for thought when/if I have to get a new trans mount when I make the switch.
thanx
05-23-2005, 07:51 PM   #8 (permalink)
psivory
FX Cruise-O-Matic
BODY 63B = Body Style Code: Galaxie 500 2-door hardtop, bench seat (197,388 produced during the 1967 model year)
COLOR M = exterior paint color: Wimbledon White (white)
TRIM 6U = interior trim color, material and front seat style: pastel parchment "Crinkle" pattern vinyl cushions, bolsters and back, bench seat
DATE 26E = scheduled build date: Friday, May 26, 1967
DSO 11 = District Sales Office: car was originally ordered through the Boston, Massachusetts sales district, which covered Maine, New Hampshire, Vermont, Massachusetts, Rhode Island and Northeastern Connecticut
AXLE 6 = rear axle ratio and type: 2.80:1 non-locking
TRANS X = transmission type and shift location: FX SelectShift Cruise-O-Matic 3-speed automatic, column shift
I got me one o them FX as well. So far mine has been fine. No slips, leaks, nada. And as far as I know it is all original. (probably shouldn't of said that, now it will most likely blow up on me
[img]/phpBB/images/smiles/icon_biggrin.gif[/img])
psivory is offline   Reply With Quote
08-30-2009, 04:50 AM   #9 (permalink)
husker70
Re: FX Cruise-O-Matic
i have a 67 galaxie with a 289/2v with a fx trans. BroaderPerformance out of tx offers 2 rebuilt the fx for cruisers. 2 handle more power i was told by them that they can build a fmx trans with the tail housing from your fx that will bolt up w/out having to change transmounts or drive shafts. i checked because i plan on swaping a built 351w(425hp) in place of the the 289. hope this info helps
husker70 is offline   Reply With Quote
