On 2005-05-26 07:55, OnCRacing wrote:
The 275/50 drag radials will work fine on 8" rims.
With the gearing in the 4R70W and a turbo windsor I would stick with 3.50 or even 3.27 gears in the rear. Turbo's like load to build boost and you don't have to spin the motor to the moon to make great power. Plus the 26" tall tire isn't helping. Look into getting some M/T drag radials, they are light years ahead of BFG's.
As an example we are building a twin 67mm turbo, 408W, glide combo for a customer. It runs 325/50/15 Drag Radials (28" tall) and will use a 3.27 gear.
What are you going to use for electronics? If your planning on running the tranny with a Baumannator and have any questions about setting it up let me know.
Curtis
http://www.oncracing.com
Starting a new thread from XXXXXX didn't want to hijack that thread...
The car currently has a ~30K mile rebuilt 352 - decent build but cast pistons etc... We (as teenagers) did a bit of prep work before having it built - took the casting flash off of the rods, deburred much of the block, etc before having it machined, balanced and assembled by a good shop... It's got the factory cruise-o-matic in it now which I expect will be the first thing to give up the ghost (although gears will help). The car also has a Top Gun N20 Plate system in it that I will use until the conversion.
Just like everything else I will always want to go bigger (twin 67's on a 408 sounds good but right now is a bit out of budget if I were going to do it right)... For now - I have the parts that I was using to put the mustang together.... I had planned on going 3.27 gears in the mustang but given the extra weight, the weak tranny, and an unknown timeline for getting the thing up on boost I think that I will go a bit steeper at first - I can always gear down (or up - numerically lower) when I actually get the turbo in... So I am guessing that this will be a staged process...
First - play with it as it is...
Second - when the tranny breaks - put in the stuff that I was assembling for the mustang (assuming that this happens before I can get a bigger inch motor built):
*Dead stock HO 5.0 ('91 forged) Mass Air - Harness Computer etc...
*60-1
*Pro-M 4"
*Tweecer RT
*Flipped shorties (still fabbing the hot side - it is nice to have more room to work in that engine bay)
*A/A FMIC
*255l/hr inline pumm
*42Lb/Hr injectors
I don't currently have a tranny (the mustang was a 5-speed) and looking at the good Bauman or Lentech stuff I think I am going to end up with a JY 4R70W for the moment and then start looking for a good valve body...
Third - Start building a big inch windsor with good (not totally priemium) stuff - dart block - 4340 rotating assy - good heads and twins - T-70s?... This starts as soon as I get the car running if it proves a bit reliable and if it breaks immediatly - after I get the 5.0 in and going...
I'll be in touch as I get there... Any advice appreciated...
<font size=-1>[ This Message was edited by: 65Custom on 5/26/05 10:59pm ]</font>
