06-03-2005, 01:03 PM   #1 (permalink)
jwe
vin number help
does anyone know were a good web site to find the vin info its a 64 galaxie 500 the vin is 4u66z173477 thanks
jwe is offline   Reply With Quote
06-03-2005, 01:36 PM   #2 (permalink)
norcal500
vin number help
1964, assembled in St. Louis, 2 dr fastback, 390 ci 4 bbl
sounds like a cool car!! Any pics?
norcal500 is offline   Reply With Quote
06-03-2005, 02:04 PM   #3 (permalink)
jwe
vin number help
coming soon
06-03-2005, 02:44 PM   #4 (permalink)
korgan
vin number help
You have PM
korgan is offline   Reply With Quote
06-04-2005, 02:55 PM   #5 (permalink)
jwe
vin number help
I JUST FOUND OUT MINE IS A TBIRE MOTOR ITS STAMPED C4SE NOT AE AND UNDER THE TEMP UNIT THEIRS A LITTEL METAL TAG . AND DO YOU KNOW HOW TO REMOVE THE FRONT DRUM. DO I HAVE TO TAKE SOME THING OFF OF IT BEFORE IT WILL COME OFF
06-04-2005, 08:38 PM   #6 (permalink)
ShotRod64
vin number help
Some of the 64s did come with the Tbird engines.
To remove the front hub/drum you need to remove that metal grease cap in the center of the hub. Then there will be a cotter key that goes through the slots on the nut and out the other side, straighten it and pull that out. Then just take the nut off and also the front wheel bearing wheel fall so take it off when it comes out enough to get hold of it. You might need to adjust the brake shoes down some but usually the front ones are easier than the rear. The spindle and drum will come off as one.
Deb
06-05-2005, 01:47 PM   #7 (permalink)
jwe
vin number help
thank you im try ever thing to get it to come .
06-05-2005, 06:00 PM   #8 (permalink)
jwe
vin number help
i took all them off i even took a bolt off the back it still wont come the buttom have will but top does not move im tryed a pry bar and a hammer it wont move
