Speedo jumping and odometer not working
He is talking about the cable...I guess? There a maybe some teflon or graphite lube...I've always used the stuff you find at the parts store. The housing is the armored outside casing that covers the flexible inside transmission cable.
If the cable maintenance doesn't solve the problem and you think the actual speedometer is the problem, personally I would have it redone by a shop. It can probably be done or swapped by the average ham-handed grease money, but not by "this" one. There are a few things I just feel are out side my area of expertise...automotive clocks, speedometers are near the top if the list.
I agree, as mentioned in the earlier message, check the cable first. It could be dry, need to be lubed, or kinked, binding on something as it turns in the housing...or both - the inside of the housing may be catching and holding the cable as it turns, then when it breaks free the stored torsion on the cable makes the needle bounce and fluctuate.
I think the interior of the cables are lined with some kind of non-stick sheath, if its damaged you may want a new cable ...I think Dennis Carpenter sells them in different lengths.
