06-24-2005, 08:54 AM   #1 (permalink)
mikhett
lowering the galaxie front end?
I rebuilt the front end on my 62 galaxie xl(new ball joints ,tie rods control arm bushings centerlink and ditched the leaky power steering and had to change the pitman arm also new coil springs and shocks) on the rear had new leaf sporings installed and new rear shocks.Now my front end sits higher than the rear and i dont like it.What can i do to lower the front?.I d like to have it sit evenly. thanks mike
mikhett is offline   Reply With Quote
06-24-2005, 09:19 AM   #2 (permalink)
serb66
It will take a bit of time for your new front coils to settle and it will drop some, maybe 500-1000 miles. I recently put new stock coils on the front of my 68 Galaxie XL. I cut 1/2 coil off each spring before installation. The front end sits a little lower than the back and it looks real good. So since you already have them installed, let them settle. Then if you want it lower, you can consider cutting them.
serb66 is offline   Reply With Quote
06-24-2005, 11:00 AM   #3 (permalink)
PhatFalcon
You can always go with lower rate springs too, but you already invested in new coils. Cutting springs will work if done with a cutting wheel.
It's been said many times before here to never torch a spring. It can cause cracking and a failure of the spring. Also cutting a half coil won't have much affect on the ride, but it will stiffen a little.
I agree to drive it for a while and let the new springs flex and settle a bit with all the new suspension components then decide. If the front is sitting where you like it you can always throw an extra leaf onto the rear.[img]/phpBB/images/smiles/icon_wink.gif[/img]
<font size=-1>[ This Message was edited by: PhatFalcon on 6/24/05 11:02pm ]</font>
06-24-2005, 09:40 PM   #4 (permalink)
southern63gal
I cut one round off my stock FE springs and people tell me they love the way it sits[img]/phpBB/images/smiles/icon_cool.gif[/img]
southern63gal is offline   Reply With Quote
06-25-2005, 11:35 AM   #5 (permalink)
southern63gal
Hows this for stance
06-25-2005, 10:11 PM   #6 (permalink)
Galaxie_406
My word! Do you live there?????
Galaxie_406 is offline   Reply With Quote
06-26-2005, 01:48 AM   #7 (permalink)
adgdghr123
My front sits slightly higher than the rear. Can hardly tell unless I ahve stuff in the trunk. Rear springs are new stock replacements, fronts are original. New shocks all around. I plan on lowering the front to fix the stance by installing my 460. [img]/phpBB/images/smiles/icon_cool.gif[/img]
adgdghr123 is offline   Reply With Quote
07-05-2005, 06:37 PM   #8 (permalink)
jwe
on the gold galaxie with the white top what kind of wheels do you have. also can you explain how you got that killer stance DID YOU JUST CUT A LEAF SPRING OFF . I would like my 64 to seat that way. thanks
jwe is offline   Reply With Quote
07-05-2005, 08:23 PM   #9 (permalink)
FoMoCo
New BB springs on mine and it went from nice and low to looking stupid high.It took a good year before it was *almost level*I would have cut a 1/2 coil had I known it would go up as much as it did.I should have just gotten new small block springs now that I think about it.Taller rear tires and that stance is ok now.
