06-29-2005, 09:27 AM   #1 (permalink)
kuch73
electrical or mechanical guages....
Looking to get some aftermarket temp guages, are the mechanical or electrical more accurate? The mech ones sell for more, are the electric ones easier to run due to smaller wires? Thanks
kuch73 is offline   Reply With Quote
06-29-2005, 02:08 PM   #2 (permalink)
64Galaxie500
id just say is whatever look you like. you want greene numbers, go digitalal, want a needle go with it.
64Galaxie500 is offline   Reply With Quote
06-29-2005, 02:12 PM   #3 (permalink)
loverboy4604
i agree some gauges that you may like arent offered in mech ... and viseversa... so go with what ya wanna put in the car and go from there..
loverboy4604 is offline   Reply With Quote
06-29-2005, 02:26 PM   #4 (permalink)
Bandido
I asked the same question when I was looking for gauges. mechanical gauges are supposed to work faster and more precise, but are more diffiulct to install.
I ended up with some sunpro gauges which were cheap and had mechanical senders. Like the guys said before, I would think if not for a high performance race motor it doesn't really matter what you pick.
1970 Ford LTD, 390, C6, all original with 50,000mls - FOR SALE -
1970 Ford Galaxie XL convertible, 460, C6
<font size=-1>[ This Message was edited by: Bandido on 6/30/05 1:26am ]</font>
Bandido is offline   Reply With Quote
06-29-2005, 03:45 PM   #5 (permalink)
M3FordBoy
I also used Sunpro mech. sender gagues I got from autozone I have never run gagues berfore and it realy wasn't that hard to install I just had to drill a 5/8" hole in the firewall and finish the conections.
M3FordBoy is offline   Reply With Quote
06-29-2005, 04:45 PM   #6 (permalink)
norcal500
If you go mechanical be sure NOT to get the gauges with the little plastic tubing for the oil. I ordered the Summit brand mechanical gauge cluster and had it all installed and it worked fine for a while, but one day I pull up to a stop light and notice no oil pressure. I happened to look underneath the car at the stoplight and sure enough a steady flow of oil dripping on the ground. The heat of the engine burned through the tube and it wasn't touching anything. I just ordered the eletrical so I don't have to deal with that mess anymore but I like the idea of the mechanical gauges.
Just realized you were talking about temp gauges and not oil so I guess your ok either way you go.
<font size=-1>[ This Message was edited by: norcal500 on 6/30/05 3:49am ]</font>
norcal500 is offline   Reply With Quote
06-30-2005, 11:44 AM   #7 (permalink)
mailmandon
I used electrical because I think that capillary tube running to the dash looks cheap and ugly.Electrical temps are harder to find.Your choices are limited unless you go with the expensive units.I also experienced the oil tube burn through.Sitting at a red light,hot oil pouring down on my leg from where my oil tube melted.Smoke started coming out from under the hood.Luckly for me I had recently decided to carry a fire extinguisher..I think electrical is safer.
mailmandon is offline   Reply With Quote
