C-6 swap into 60-64 Galaxie
Great photos, really appreciate that. Looks like we will be able to use the existing frame mount with the crites cross member. Curious, the FMX cross member not oly had the 2 long bolts but also had additional bolts for the crossmember plate. It appears that you can only use the two long bolts or is there another bracket that bolts to the bottom of the new crossmember?
