C-6 swap into 60-64 Galaxie
Cool on the drive shaft. I have an extra crossmember for the gal. I think I will modify that one and get everything ready for when I do the swap. What do you know on the the rear transmount, the donor car (Mercury) which had the FE in it had a different transmount which had 3 bolts in it and wraped around from the rear, however it was broke. I used the 6-cyl one because it still bolted up. Do you know if the 3 bolt type as described was specific to the Merc or I need to change from the one I am using to this other type.
