Seat Question
It can be done if you use the force.... and some 1/2" pipe and some big washers... and a hack saw and a couple extra blades... and a drill.... Anything will fit with if you have those tools.... [img]/phpBB/images/smiles/icon_wink.gif[/img]
Get a tape and measure the witdth of a vic and the 64 to see if you will have door closure problems... You shouldn't have any problem even if the crown vic is a wider car because the doors are thicker and the inside panels are thicker, so the seats should not be too wide...
