10-04-2005, 01:35 PM   #1 (permalink)
mailmandon
How do you remove the ignition switch in a 64?
I thought I knew how the switch lock came out but I can't get it out.Don't you put a drill bit in the little hole in the front and turn the key to remove the lock?Then the bezel screws off I thought. If not,how is it done?
mailmandon is offline   Reply With Quote
10-04-2005, 01:43 PM   #2 (permalink)
jwe
u can use a paper clip .just put it in the little hole and turn it over to acc it sould pop right out
jwe is offline   Reply With Quote
10-04-2005, 04:00 PM   #3 (permalink)
Gotta have a key! then it's a cinch....
10-04-2005, 04:40 PM   #4 (permalink)
63ford406
After you get the lock out push the switch from the back toward you and hold the bezzel and twist the switch at the same time. Also you have to turn the key passed the acc position to get the lock out.
63ford406 is offline   Reply With Quote
10-04-2005, 05:10 PM   #5 (permalink)
mailmandon
Thanks. I got it. I just had to work with it a bit.I guess age made it kinda sticky.
