11-09-2005, 09:58 PM   #1 (permalink)
Gordo
Gas Tank Drain Plug ?
Now that winter is setting in, I got to thinking about draining the gas from my tank. Usually I add stabilizer, but a total drain would be nice.
Has anyone found a good drain kit, plug or anything that allows for easy draining during the off season? Something that could be threaded in? My first impression is that it would be difficult to get a good seal. Then there is the issue of drilling a gas tank !!
Gordo is offline   Reply With Quote
11-09-2005, 10:19 PM   #2 (permalink)
admin
Hmm, you sure the tank doesn't have a drain already? Most do, in one of the corners.
admin is offline   Reply With Quote
11-09-2005, 10:37 PM   #3 (permalink)
Beoweolf
I have never seen a factory installed drain plug on any 60's or above Galaxie Fuel tanks. Much like the early drain plugs on rear axles and automatic transmission oil pans; somewhere along the way the factory seems to have decided they were no longer needed. You would think they were worth keeping?
11-10-2005, 02:11 AM   #4 (permalink)
64Ragtop
My 64 has a factory installed drain plug on the gas tank it came in real handy when I had to change the sending unit for the gas gauge.
64Ragtop is offline   Reply With Quote
11-10-2005, 02:12 AM   #5 (permalink)
64Ragtop
11-10-2005, 05:34 AM   #6 (permalink)
wildosvt01
The 65's dont have a drain plug, As Beoweolf stated already.
<font size=-1>[ This Message was edited by: wildosvt01 on 11/10/05 5:34pm ]</font>
11-10-2005, 06:48 PM   #7 (permalink)
will4685
My 64 stock tank had a drain plug. So does the new replacement tank made with the stock tooling.
-Will
will4685 is offline   Reply With Quote
11-10-2005, 06:58 PM   #8 (permalink)
rayell
My 64 gal has the original gas tank and it does not have a drain plug. It ia a late model 64: built 4-64. I have noticed a lot of differences in my car and ones built early in the model year.
rayell is offline   Reply With Quote
11-10-2005, 07:19 PM   #9 (permalink)
ford4v429
I would suggest if youre not going to be pulling the tank or otherwise working on it, just to top it off and add stabilizer- wont take long to use a tank in the spring [img]/phpBB/images/smiles/icon_smile.gif[/img]
I was told that what usually causes rust in the tanks is a non-full tank- temperature changes cause condensation above the fuel level from air expanding/contracting during temp changes from day/night...if the tanks full or almost full, theres very little air to expand/contract and draw in moisture...add a bottle of dry-gas(alcohol) to absorb any small amount of moisture- thats what a buddy told me long ago, and it seemed to make sense.
I agree a drain would be nice, now wish I woulda added one when I flushed/sealed my tank, just in case I ever want to drain/remove it for any reason...I'd not want to drill a hole even in an empty tank...a guy at work was changing a fuel line on his racecar a year or so ago, knocked over his troublelight and poof- put him in the burn ward for a month, lost his car and garage...almost an arm. even a few drops of gas on your clothes can make ya a torch real easy. I for one had never even thought of 'what if' I dropped a troublelight...even the smallest spark and its all over.
ford4v429 is offline   Reply With Quote
11-10-2005, 10:05 PM   #10 (permalink)
64Ragtop
I've looked at this statement and don't see 65 any where in it?[img]/phpBB/images/smiles/icon_razz.gif[/img]
