This came up a while back. Here's a good source for Anodizing remover. The nice thing about this stuff is the part is submerged so the whole thing gets the same treatment. The oven cleaner is kind of spotty in how it takes it off. Not to mention expensive and wastefull.
[img]/phpBB/images/smiles/icon_bow.gif[/img]
Village Buffing Supplies
Boyd & Reba Hardin
902 East 22nd. St.
Kannapolis, NC 28083
Phone - 704-933-0084
Fax - 704-933-4180
E-mail -
villbuff@vnet.net
Link -
http://www.Villagebuffing.com
It's a chemical solution that looks like powdered detergent. ( Sodium
Hydroxide ) You mix a small amount with water and then soak your aluminum
part in it for about 10 - 15 minutes, sometimes longer. During that time
the part will start to react with the solution and the hard anodized
surface on the part will dissolve into the solution. (the solution starts
to fizz and bubble)
After you feel it's all gone, you rinse the part off with clean
water and the part will have a very dull, but smooth appearance. Then you
polish it just like you would any other piece of aluminum that you'd want
a nice finish on. This is also a good time to work out any dents or
scratches you need to fix. You can use buffing compounds, Wenol, Mothers,
etc. Then you have the option of either applying some kind of clear to
protect it, like POR-15's "Glisten PC". Eastwood has a clear also, but
it didn't hold up well when I tried it on some trim for another project.
Some people opt to just keep the aluminum shinned up and waxed
periodically, with Mothers, Eagle wadding polish, semichrome polish,
Wenol, Zoops, etc. If your car's not out in the weather all the time that may be
OK. If it's going to see weather it might be best to cover it.
This little jar will make several gallons of solution. If you
save it in jugs you can keep it for years. I have some several years old
that is still strong.
________________
Phil
FGCoA # 694
63 Fastback
64 F-100 4x4
66 Mustang
http://groups.msn.com/FordGalaxieCol...umfinishd.msnw
<font size=-1>[ This Message was edited by: Customcab on 1/14/06 5:17am ]</font>
<font size=-1>[ This Message was edited by: Customcab on 1/14/06 5:21am ]</font>
