Automatic to Manual 351C
jhovis, I applaud you for looking to make your Galaxie a fun car. Nothing like a manual transmission to take the boring out of driving, IMHO. I have done it on 2 Galaxies and enjoy the results immensely.
I am a big admirer of the 351C, and have always thought the dumb b*stard at Ford who ordered its demise should be boiled alive in a tar pit, especially since they eventually derived the totally lame*ss 351M from the design, managing once again to completely screw things up, performance-wise. However, much as I love the 351C, I prefer to see them in their native habitat... early '70's Mustangs, Torinos, Cyclones, Cougars, etc.
Since a properly built 352/390/428 is such a powerhouse, why not stick with the historically correct and awesomely attractive original FE layout that will totally kick bowtie butt? The simplest, most straightforward swap you can make is to use an FE motor, a Galaxie toploader, and '65-'68 Galaxie pedals, clutch linkage, z-bar, with a C5AA (car! not C5TA truck!) bellhousing with the correct clutch release fork. You will also need the Galaxie FE manual transmission cross member (a 3spd crossmember is just fine). You can find everything but the crossmember in a small block or 6 cylinder Galaxie. The cross member can be fairly easily fabricated.
A small hole will need to be cut in the existing transmission hump to which you will bolt the shifter hump. Crites supplies a nice '64 shifter hump that works well with the '65-68 trans hump.
You can use either a Hurst or factory Ford shifter. For racing, the Hurst can't be beat. For mostly street driving, the Ford is great as the handle is nicely mated to the seat and driver position, whereas the Hurst forces you to lean forward with every shift... and that gets old fast for daily driving.
Regarding the transmission, a toploader is easily the strongest 4spd ever made, and stronger than nearly all factory 5 spds. While the OD gear in the 5 spd is good for highway driving, consider sticking with the 3.00:1 rear end ratio you currently have. With P235-75R15 tires, you will achieve the rough equivelant of the OD gear and a 3.5: ratio. Unless you intend to do a lot of racing, this makes sense in the era of costly gasoline.
jhovis, let me also caution you about listening to the advice of many "machininsts/mechanics/hotrodders." Many know next to nothing about the FE motor and cover up their lack of familiarity with disdain and insults. IT IS ONE OF THE MOST ACCOMPLISHED ENGINES IN AUTOMOTIVE HISTORY, AND IS AN EXCELLENT ENGINE FOR ALL PURPOSES EXCEPT LOW EPA EMISSIONS. I repeat, do not listen to BrandX afficiandos or other know-nothings in making your decision. Talk to a well-versed FE machinist... you'll be glad you did!
Enjoy the FE, enjoy the toploader, increase the value of your Galaxie! Keep us posted.
