06-01-2006, 06:19 AM   #1 (permalink)
pasvorto
trunk lid antenna
My 64 has a radio antenna in the middle of the trunk lid. Evidently, a few years back (before I bought it), someone busted it off. I removed the remaining stub from the mount. I have looked through all my catalogues and can't find a replacement anywhere. Does anyone have any suggestions st to where I can find just the antenna? Or, even, where I could find the whole unit?
I plan to put in an AM/FM/CD unit and need the antenna for the AM/FM part.
pasvorto is offline   Reply With Quote
06-01-2006, 04:46 PM   #2 (permalink)
loverboy4604
trunk lid antenna
try radio shack.. or your local dept store .. walmart....
if ya have the stub still take it along for comparison
loverboy4604 is offline   Reply With Quote
06-01-2006, 06:05 PM   #3 (permalink)
sleepysal
trunk lid antenna
you can get antenna repair mast they screw onto the old base or over your stub, try pep boys ore a stereo shop
06-02-2006, 05:24 AM   #4 (permalink)
pasvorto
trunk lid antenna
The local audio shop didn't have anything and the Ford parts guy is still laughing..
I brought the sub and the antenna in to work this morning. One of our machine shop guys is going to try and drill a hole through the stub and the antenna and put a dowel in it. Then, with a bit of JB Weld in the joint, maybe I can stiffen it up a bit.
If it had been a fender antenna, no problem. But, if I take this one off, I have a big hole in my trunk lid. Not good.
I ordered new knobs for the radio. Maybe I can get at least AM this year.
06-02-2006, 07:37 AM   #5 (permalink)
sleepysal
trunk lid antenna
worse case buy a hidden anntenna it will mount inside your car about 35-40 from auto loc.
06-02-2006, 08:07 AM   #6 (permalink)
pasvorto
trunk lid antenna
That's an option. I talked to the machinist. The dowel won't work. He is going to epoxy the stub to the atenna (where it is supposed to go), then when it is dry he will drill a hole all the way through both pieces and put in a screw. That should hold it in place.
Geez, all this to get a AM radio working again...
