12-19-2006, 11:26 AM   #1 (permalink)
GalaxieJoe67
offset shaft crossmember Bolt
Where can you find replacments for the bolt that screws into the front crossmember that holds the offset shaft? The one on the pass. side of my car was welded to the frame! I can get the car out of my class using the old stuff but i would like to find a replacments.
Joe
GalaxieJoe67 is offline   Reply With Quote
12-20-2006, 01:07 AM   #2 (permalink)
63galaxie2
I may have some.Ill check.Are you sure the nuts are still good?
63galaxie2 is offline   Reply With Quote
12-20-2006, 11:47 AM   #3 (permalink)
GalaxieJoe67
Thanks for the reply put iam ok my solid mout kit came in yesterday so I wont have to put the old system to get the car out of my chassis class.
Joe
P.S. if any one needs a link bar to hold the offset shafts still, I have one up for sale now
12-20-2006, 12:58 PM   #4 (permalink)
64squire
Joe, which solid offset kit did you buy?
John
64squire is offline   Reply With Quote
12-21-2006, 12:18 PM   #5 (permalink)
GalaxieJoe67
I was able to get the Rare Parts item at my local Advanced Auto, it was a little more then what is listed in the Dearborn Classics book but not much (I got a student discount). Nice kit, it has 2 smaller can bushings that fit in the front of the cross member and 2 larger ones that ride on a lip on the rear of the cross member withg a foot long grde 8 bolt. Rigth not my car is sitting high in the front after installing a Kanter front end kit, KYB shocks, and solid mount kit, strange? My car in a mix of parts with few modifications right now, i just have to get back under it when school starts up again.
Joe
12-21-2006, 12:21 PM   #6 (permalink)
GalaxieJoe67
I was able to get the Rare Parts item at my local Advanced Auto, it was a little more then what is listed in the Dearborn Classics book but not much (I got a student discount). Nice kit, it has 2 smaller can bushings that fit in the front of the cross member and 2 larger ones that ride on a lip on the rear of the cross member withg a foot long grde 8 bolt. Rigth now my car is sitting high in the front after installing a Kanter front end kit, KYB shocks, the solid mount kit, and urathane sway bar bushngs, strange? My car in a mix of parts with few modifications right now, I just have to get back under it when school starts up again.
12-22-2006, 07:07 AM   #7 (permalink)
drewsom21771
Joe How much$$$$ and do you have a P/N
drewsom21771 is offline   Reply With Quote
12-23-2006, 12:48 PM   #8 (permalink)
GalaxieJoe67
18021 it wont be listed in there parts book on on the computer at Advanced will have to call about it, cost at Advanced around 300. I know I could of got it a littler cheaper some place elese but I needed it now. Its the same part that is listed in the dearborn classics book OSH14. Sorry my post got put up twice. I found out why the rear of my car is so low to the ground, when I got it off the lift the shackle floped to the other side of the frame bracket. With the new bushing and everything the front of the car is real stiff.
Joe
