Water Leak
Drivers side door rubber or the windshield rubber. Those are the only two things that let water into your cab at that location.
Very hard to see if the windshield rubber is leaking but easy to tell if it's that.
When it is not raining, run the garden hose across the windshield ONLY (Insulate the door from the water) if it don't leak inside then you have a door frame seal issue, if it does you likely have aged and cracked windshield dope and need a refresh.
FE
