02-21-2007, 06:10 PM   #1 (permalink)
64GALAXIE514
Rad hose for a 64 w/ 460 and an FE rad?
I need a rad hose, the lower, for a 460 connecting to a FE rad. As far as I can tell, the water pump is 2" and the rad is 1.75" outlet. Will a stock 390 hose work? What has everyone done? Thanks.
64GALAXIE514 is offline   Reply With Quote
02-21-2007, 09:31 PM   #2 (permalink)
63ford406
Not that far along on the one I'm doing. Why not buy one and try it. If it won't work take it back. Look in a Gates Rad. hose and belt buyers guide book and see what will work. It has pictures and measurements.
63ford406 is offline   Reply With Quote
02-22-2007, 04:15 PM   #3 (permalink)
FoMoCo
Simply bend a coat hanger to the shape you need and take that to napa and start going through hoses till you find one that will fit. I found mine this way and ended up using a section of a bigger hose which I have no clue what it was for.
02-22-2007, 06:59 PM   #4 (permalink)
64GALAXIE514
We did, still no dice, but close. I have ordered one for an FE engine so we'll see.
