Any one have a spare window regulator drivers front crank mechanism for a 63 ford station wagon? Mine is toast.
Are they all the same? Would a 4 dr mechanism work?
When I crank mine down it goes down about 1/2 way then I have to push the window down a bit then it catches again. When I crank it up I have to do the opposite. Is it just a bad tooth on the gear?
"Guess What? I gotta Fevr and the only perscription is? MORE COWBELL!!!" Christopher Walkin
