11-24-2007, 05:57 PM   #1 (permalink)
lgh1157
Galaxie Club Offset conversion shaft - who does it ?
Im in the process of rebuilding my front end, actually im in the process of putting my front end back together , with disc brakes and airbags.
I hate the offset bolt and im thinking while im in there i might as well replace it, i had a kit and i sold it [ not thinking i would be rebuilding my front end anytime soon ] to one of you guys on here , kinda stupid of me.
I know one of the Galaxie club guys does this conversion.
Anyone know who to talk to ?
Heres a pic of the Mod :
PANEL BEATERS C.C - WE GOT GREASE UNDER OUR NAILS, NOT IN OUR HAIR
lgh1157 is offline   Reply With Quote
11-24-2007, 06:04 PM   #2 (permalink)
lgh1157
Re: Galaxie Club Offset conversion shaft - who does it ?
I found it, i was gonna delete my post but i figured someone might want the info
  • Suspension conversion kits for 1963 and 1964 Galaxies! Do away with that pain in the behind offset shaft that is in the front of the lower control arms. This conversion gives you a complete set up for both sides so that you don't have the alignment problems. $175.00 + $12.00 shipping, with your concentric nut core exchange (add a $50 deposit if you cannot furnish cores-refundable upon receipt of good cores). With this conversion you won't need toe in bars, or new bushings or offset shafts when you rebuild your front end. All you will need is this kit and you are back in business. DOES NOT look 100% original. Just makes the car handle 100% better. Make checks out to Mark Reynolds
    Postal Money Order gets IMMEDIATE shipment upon receipt. (unless item is backordered) Checks take 7 business days to clear.
    PO Box 429, Valley Springs, Arkansas, 72682 870-743-9757 (AR) or E-mail markr@bornagainclassics.com {11-8-07}"
http://bornagainclassics.com/products.html
11-25-2007, 11:29 AM   #3 (permalink)
ShotRod64
I think Bill Gerstenberg of So-Cal does them also. But you had to move.
Deb
Always be yourself, because the people that matter don't mind, and the ones who mind, don't matter.
www.so-calgalaxies.com
www.galaxiesnw.com
11-25-2007, 12:05 PM   #4 (permalink)
southern63gal
What about taking the shaft to a machine shop and having one made without the offset? I have a brother in law who says he will do it but we need to know what material
[img]http://i68.photobucket.com/albums/i14/southern63gal/m15tu-2.jpg[/img]
southern63gal is offline   Reply With Quote
11-25-2007, 03:19 PM   #5 (permalink)
lgh1157
Deb
Deb, do you know how much Bill charges for the kit ?
southern63gal - All the kit in the pic is, is a grade 8 bolt with a thick washer. The washer makes up the thickness of the "offset" part of the bolt.
I have a few extra bolts that run through the frame, i might play with em and see what i can come up with
L
11-25-2007, 05:39 PM   #6 (permalink)
ShotRod64
L
Sure don't L. I can find his number and pm it to you if you want so you can call him.
Deb
www.galaxiesnw.com
11-25-2007, 10:12 PM   #7 (permalink)
lgh1157
^ thanks Deb, i hit up Richard and hes gonna ask him the details
11-26-2007, 08:30 AM   #8 (permalink)
64Ragtop
There used to be a guy on this sitE named Greg Cook and he had a car Battlestar Galaticia a 63 that did wheeles off the line and he said that he just welded his in the down position and it was done a couple of years ago seems to me to be a cheap way of doing this instead of paying $170+ DOLLARS.
64Ragtop is offline   Reply With Quote
11-20-2008, 01:46 PM   #9 (permalink)
KenF
HI this is KenF I am considering doing the offset shaft swap by using the kit from Bill in Orange CA does it do what its supposed to Thanks Ken
KenF is offline   Reply With Quote
11-20-2008, 03:22 PM   #10 (permalink)
KenF
HI did you ever fit that offset shaft replacement cheers Ken
63 Offset shaft installation question 69boss9 Galaxie Pages 6 11-25-2007 10:52 PM
offset shaft crossmember Bolt GalaxieJoe67 Galaxie Pages 7 12-23-2006 12:48 PM
59 ford galaxie wheel offset 59wagonman Galaxie Pages 1 12-18-2006 05:13 PM
Offset shaft conversion lgh1157 Galaxie Pages 36 01-16-2006 10:29 PM
63 lower a-arm offset pivot shaft ??? tonyD Galaxie Pages 3 10-10-2005 08:07 AM
