12-04-2007, 06:38 AM   #1 (permalink)
66_galaxie5
How to fix my trunk?
My trunk will not stay up, I think I am missing a part. Can someone take a picture of the hardware inside their 66 galaxie?
thanks..............
1966 Galaxie 500
289-2V
FX Cruise-O-Matic 3-speed
3.00:1 non-locking
66_galaxie5 is offline   Reply With Quote
12-04-2007, 06:59 AM   #2 (permalink)
Chooch65
Re: How to fix my trunk?
The spring tension rods are probably not hooked up right or are missing. They go between the hinges up under the package tray area. Two long skinny steel rods that snap into place on the teeth that are a part of the hinge mount. Be careful! They are tricky and under a lot of tension.
The 2nd Revolution is on its way!!!
Chooch65 is offline   Reply With Quote
12-06-2007, 04:39 PM   #3 (permalink)
Bumblebee
66,
tomorrow I will take the trim pieces out of my trunk and snap a shot or 2 for ya... may not be pretty but should get ya goin'. Mine is a 65 but similar body, should have the same or very similar torsion rods.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.Albert Einstein
Bumblebee is offline   Reply With Quote
12-07-2007, 06:24 AM   #4 (permalink)
66_galaxie5
thanks fellas!!!!
1966 Galaxie 500
289-2V
3.00:1 non-locking
12-07-2007, 09:43 PM   #5 (permalink)
Bumblebee
OK 66,
Hope this helps.
12-09-2007, 02:59 PM   #6 (permalink)
66_galaxie5
Okay, I do have the spring tension rods in place but notice there is a loose part between the inside of the hinge. The picture of the right hinge shows the tension rods. (on the other side of the rod is that piece I am trying to describe) Anyone know how that part is connected?
1966 Galaxie 500
289-2V
3.00:1 non-locking
12-09-2007, 04:42 PM   #7 (permalink)
Bumblebee
Will try for another pic tomprrow of the inside of the hinge to see if it will help ya. PS.... DO be careful adjusting and messing with these things....dont want ya losing a finger now do we?
12-09-2007, 07:20 PM   #8 (permalink)
Bumblebee
OK... to hell with tomorrow..stopped by the house and snapped a few... here they are. Hope they help. The ones that arent yellow are taken from the passenger compartment with the back seat removed (the back side of the hinge)
Good luck
12-09-2007, 07:28 PM   #9 (permalink)
Bumblebee
66,
I just took a look at the pics I snapped and reviewed your question. It looks like they may be cold riveted or some sort of a blind screw (chicago screw type) assembly. It may be that there is enough room for a nut and bolt but I would ONLY use grade 8 hardware on it. That assembly is under a lot of tension and grade 5 might shear off...just a thought.. I would use lock-tight on the nut as well IMO.
Good luck
12-09-2007, 07:47 PM   #10 (permalink)
66_galaxie5
I appreciate the pics bumble...I will try to look at it tomorrow but I think that I am missing the driver side part that I was describing earlier. Judging by your pics you have one each side. thanks for taking the time...
1966 Galaxie 500
289-2V
3.00:1 non-locking
67 Fastback trunk lid ? southern63gal Mustang Pages (1965-1973) 8 11-21-2007 04:01 PM
\'64 trunk lid 64390xl Galaxie Pages 3 12-17-2006 07:43 PM
63 and 64 use the same trunk? PeiceOfPaper Galaxie Pages 2 10-19-2005 06:42 AM
what\'s in your trunk??? Bandido Galaxie Pages 7 05-23-2005 01:33 PM
Anyone up on trunk mats? deleted2 The Garage 6 12-16-2003 08:06 AM
