10-30-2009, 05:00 PM   #11 (permalink)
Dave66Galaxie
Re: '65 A/C Retrofit?
I also seem too recall the A/C belt used 2 idlers. One was a fixed one beneath the compressor, and an adjustable one mounted above the alternator.
Dave66Galaxie is offline   Reply With Quote
11-02-2009, 05:34 AM   #12 (permalink)
oneputtster
Dave is correct. The AC belt is the longest at maybe 60 inches.
There are two brackets, a large one that cradles the PS pump and an L-shaped one that the AC sits on. To attach them, screw two threaded-on-both-sides bolts (get at hardware store) into the block, then put the AC bracket on, then the PS bracket over that, then tighten all down with the nuts.
The PS bracket has a notch in it that a bolt on the back of the pump fits into.
Putts drives a 1965 Galaxie 500 4dr. 352 4V AC PS PDrumB cruis-o-matic.
oneputtster is offline   Reply With Quote
11-03-2009, 09:44 PM   #13 (permalink)
Dave66Galaxie
Found this photo on an Ebay ad.
A/C retrofit alchee Truck Forum 3 02-06-2007 11:39 PM
retrofit roller cam swap pbsant All Ford Techboard 6 09-17-2006 10:50 PM
Pushrod lenth with retrofit kit smokey212 All Ford Techboard 6 03-19-2005 08:38 AM
Retrofit Pulleys??? CougarKid All Ford Techboard 4 01-15-2002 09:14 PM
pulley retrofit frdnut All Ford Techboard 2 01-14-2002 03:22 PM
