Re: Ford 352
352 can be a nice motor. I felt the 390 motor that came in my 64 was a little under powered when paired up to the cruis-o-matic transmission. With a four speed it may have been different. You can run any aluminum intake and save a lot of weight off the motor. If you are going to do heads, do them right away. It's a pain in the a$$ to have remove the rockers and pushrods just to install a manifold then have to do it again with heads.
Bang for the buck would be to upgrade the carb and cam while replacing the intake manifold and throwing on a set of good FPA tri-y headers.
I personally like more than what the FE motor can safely and reliably produce. That's the main reason the 64 vert I am currently building is going to be breathing life through a 514 mated to an AOD. That's just me and up here in Montana there are a lot of really long roads with very few highway patrolmen. :^)
Just make sure if you are going to build the motor in steps that you plan it out thoroughly. Nothing sucks pineapples more than have to replace something that you just installed due to incompatibility. Good luck.
64 Galaxie 500 XL (constantly morphing)
FE 431 Stroker, C-6, Comp/Crane Roller assembly, FPA headers, Edelbrock heads, Zex n2o, Hydroboost.
