02-05-2008, 01:41 PM   #21 (permalink)
saleen428
Re: Engine Pinging After a Freeway Run
Thanks Bumblebee.
Those are the exact ones I was looking at and will probably end up buying.
Rob
'69 Galaxie 500 Hardtop, 390 cu, Dual 2.5 exhaust with FlowMasters,17x8 Torq-Lites, Custom Lowered Springs. Thats All for Now...Maybe next time there'll be more..
saleen428 is offline   Reply With Quote
02-05-2008, 11:07 PM   #22 (permalink)
Bumblebee
I was at Summit the other day and looked over the display... Looked every bit as nice as the Griffin. Heavy duty and welded not glued together. Cheaper than an aftermarket replacement too but will have to do something about mounts as they are cross flow not vertical. I will be doing one in the 65 once I get that far...
Keith/ Bumble
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.Albert Einstein
Bumblebee is offline   Reply With Quote
02-05-2008, 11:34 PM   #23 (permalink)
saleen428
The Summit radiators I have purchased have been made by Nothern. Northern stamps their name on the bottom of the radiator.
The only issue with these radiators is the lack of petcock to aid with draining. Not sure why, but these Northern lower radiator outlet is not at the bottom of the radiator tank. They are raised at least 1.5" up which is not good at facilitating a drain job.
Rob
Engine "hiccups" at freeway speed galaxiegray Galaxie Pages 18 09-21-2007 11:14 AM
stroker engine pinging rcodenewf All Ford Techboard 7 09-15-2007 06:20 PM
New exhaust let me hear that my engine wasn\'t pinging... Hello performance and mileage! adgdghr123 The Garage 0 06-17-2004 02:34 PM
Engine loading up? Black smoke and pinging kywookie All Ford Techboard 3 09-30-2003 09:18 PM
vibration on the freeway andysam All Ford Techboard 17 02-08-2003 08:01 PM
