Ok. I have a 1964 Galaxie with the 390 and an auto. When we bought the car it supposedly hadn't been started in the last 15 years. Here are the steps we have taken so far to get it started.
1. We verified we had spark - we do
2. We verified gas was getting to the carb - it is
3. We unhooked the fuel line running to the gas tank and ran it into a jug to verify fresh gas
4. We verified a good battery by jumping the car with my truck
Problems
1. We can't use the key to try to start/ crank the car over - the gen light comes on but nothing happens when we turn it to try to fire it
2. We tried jumping the solinoid - this got the car to fire but would not stay
3. We cannot use the throttle - for some reason it will not move. We even disconnected the linkage to verify it wasn't binding. It wasn't. But we can't manually crank the throttle at the carb. Why not? This seems odd. Why can't I blip the throttle at the carb?
I would think I could keep the car running if I could tweak the throttle. What do I need to check here to fix this?
Also, why can't I use the key? I know I just trashed the solinoid today. If I replaced this, do you think the key will work?
Here are a few pics of what I'm working with.
THanks for the help!
