After years of searching for motors,or a good place to have them rebuilt for my 64 Galaxie 500, I found a place that had what I needed.It's called Nu-Relics. Their kits are complete with wiring, and a relay so you can use the stock switches! Last fall I put them in my front doors, [A bolt in!] using stock holes.I only had to drill 1 hole that was not oppened at the assembly line at Ford. Went in rather easy,but I did have to remove the window stop.They work great so far! I'm going to do the back this spring. They go for around $200 a window, But that is with motors, regulators,relay,and wire harnesses. They also come with a lifetime warranty,and are very well made! I wouldn't normally talk up a product,but after searching so long,and a well made kit like these are,I am glad I replaced my stock power window guts.
Go to Nu-Relics.com or call 336-699-8949
