04-06-2008, 09:38 PM   #1 (permalink)
nast67
Hurst Shifter
I've got the 4-speed toploader and want to change out the shifter in the car. Where can I get the Hurst shifter for my application?
Part Number?
nast67 is offline   Reply With Quote
04-06-2008, 10:00 PM   #2 (permalink)
63ford406
Re: Hurst Shifter
Sumit Racing or David Kee Toploaders
Ford Galaxie Club of America #665
So-Cal Galaxies
63ford406 is offline   Reply With Quote
04-06-2008, 10:18 PM   #3 (permalink)
nast67
Re: Hurst Shifter
Mines in a 67 Galaxie. Do I need to order all new linkage or does it come with it? Or use factory?
04-07-2008, 04:46 AM   #4 (permalink)
673904spd
Re: Hurst Shifter
Depending in what you want to do.....
This is what I just did with my '67
http://www.fordmuscle.com/forums/gal...howdy-all.html
I used this shifter...(you cannot use the delivered handle as it will come out thru the side of the console, or space it over, but I think the handle would be too short)
Hurst 3916848 - Hurst Competition/Plus Shifters - summitracing.com
With this install kit...
Hurst 3733166 - Hurst Competition/Plus Shifter Installation Kits - summitracing.com
Or, if you want the Hurst I took out, it works fine, I just didn't care for the handle location. Hurst no longer makes this particular shifter and I didn't want to modify it. And it does fit the console opening. I have more pics if you are interested.
I will take $200 for the Hurst I took out.
Jim
673904spd is offline   Reply With Quote
04-08-2008, 08:08 AM   #5 (permalink)
coosbaylumber
Re: Hurst Shifter
When Hurst began delivering their shifters for Fords, they added a removable handle like on the earlier stuff. They may say Hurst on outside, but are completely different that what they sold over the counter at the speed shop. The Ford design is rather pricey, the Hurst version is not.
Be sure you know what the difference is before obtaining any replacement parts. For the Hurst link ends were cheaper (and closer) via a local speed shop, but wrong design too. I had to get mine via the dealership (on special order). They may look the same and read the same, but they are not the same.
Wm.
Old Ford owner
04-08-2008, 10:38 AM   #6 (permalink)
673904spd
Re: Hurst Shifter
The shifter I just removed is in fact a Hurst Competition Plus, and looks exactly like the brand new Hurst Competition Plus I just bought, with the exception of the new shifter having 2-bolts to remove the handle, and the one I took out of the car having a 1-peice handle that goes all the way into the shifter body. This is not the factory Ford shifter. That was in the car when I bought it, and I still have in a box in the garage.
Jim
04-08-2008, 08:50 PM   #7 (permalink)
lnmrmn
Re: Hurst Shifter
Well, well, well, it must be spring time. They are all coming out of the wood work now. How are you doing 673904spd? Havent heard from you in a while.
[img]http://members.aol.com/lnmrmn/nmra.jpg[/img]
lnmrmn is offline   Reply With Quote
04-09-2008, 06:28 AM   #8 (permalink)
673904spd
Re: Hurst Shifter
Hey Bub!
I check in every now and then, just don't post much....
I've just been busy with a little bit of everything here lately.
Hope you and yours are doin' good...
Jim
hurst shifter southern63gal Mustang Pages (1965-1973) 2 02-03-2006 10:05 PM
Hurst shifter Krazykrenz The Garage 1 08-22-2005 10:06 AM
Need Hurst Shifter Stick Riley Falcon Pages 0 07-22-2004 05:13 PM
anyone need a hurst shifter??? dark7068 The Garage 0 06-18-2004 06:31 PM
Hurst shifter ratter1 All Ford Techboard 1 08-09-2002 11:16 AM
