05-10-2008, 02:31 PM   #11 (permalink)
Bumblebee
Re: Speaking of torque converter stall.....
Just googled it.... my bad... up to 69 Ford used a 24 spline input shaft with a diameter of .788. 1970 and later went to a 26 spline with a diameter of .839
C4 Transmission Performance Rebuild - Mustang & Fords Magazine
I guess 66 got into my head as I have a 66 c4 up in my shed waiting for a rebuild.....
Keith/Bumble
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.Albert Einstein
Bumblebee is offline   Reply With Quote
05-10-2008, 02:33 PM   #12 (permalink)
468hmmr
Keith/Bumble
Not a C4, a Cruise-O-Matic.
1965 Galaxie 500 two door hardtop 352
1966 Howard v-drive flatbottom w/
468c.i. Holman Moody medium-riser
HM Weber manifold with 48 IDA\'s
HM 180 degree headers
HM oil pan, oil cooler, etc.
468hmmr is offline   Reply With Quote
05-10-2008, 07:27 PM   #13 (permalink)
Dave66Galaxie
I believe all Ford automatics were called Cruise-O-Matic. C-4, cast iron case, or C-6. At least in 1966 I think that was the case.
Dave66Galaxie is offline   Reply With Quote
05-10-2008, 09:26 PM   #14 (permalink)
468hmmr
Mines the FX or MX type. Absolutely nothing to do with a C4 or C6. I guess I'll get the car up on stands tomorrow and see what numbers are on the ID plate. These things are confusing! Large case, small case, medium case, MX, FX, FMX!
05-11-2008, 04:41 PM   #15 (permalink)
468hmmr
Question Re: Speaking of torque converter stall.....
Ok, here's what I found. Case is iron (magnet sticks). Pan looks like the FX pan with the filler tube going in the side but, it has 14 bolts not 13. The case, minus the flange for the rear pump measures 9 7/8". The vacuum modulator is on the left rear. The tag reads:
PCD Z
352 4L 6B
What have I got?
Thanks for all your help!
speaking-torque-converter-stall-cruise-o-matic-20i_d__6.gif   speaking-torque-converter-stall-fmabpg21r.gif   speaking-torque-converter-stall-fmmcsec10pg2.gif
Torque converter stall vs. gear ratio change? 468hmmr All Ford Techboard 8 02-05-2008 10:16 PM
c6 torque converter 3000-3500 stall 65 Galaxie 500 Wanted 0 11-04-2007 09:02 PM
torque converter stall speed atarghe1 Late Model EFI Techboard 12 01-29-2004 07:02 PM
c4 torque converter stall can-am All Ford Techboard 1 09-25-2002 08:53 PM
what stall torque converter do I need? luebben All Ford Techboard 3 08-13-2002 07:56 PM
