05-07-2008, 09:39 PM
468hmmr
Speaking of torque converter stall.....
There's a 2400 stall converter for a Cruise-O-Matic on EvilPay. Would that be to much for my Gal? 352 mild cam, 4100, 3.00 rear.
1965 Galaxie 500 two door hardtop 352
1966 Howard v-drive flatbottom w/
468c.i. Holman Moody medium-riser
HM Weber manifold with 48 IDA\'s
HM 180 degree headers
HM oil pan, oil cooler, etc.
05-08-2008, 02:58 AM
Mikes66
Re: Speaking of torque converter stall.....
Make sure you know the input spline size before buying a converter. Two different converters for the C4's.
Evilpay?? Sounds like a risk all buy itself...
Get the tag number off of the tranni, and it will tell you what you need to know.
The tranni could have been swaped out at some point in it's life.
2400, is a good converter for a heavy car.
[SIGPIC][/SIGPIC]
05-08-2008, 06:36 AM
gbeeler
I think Mikes66 didn't see that you have a Cruis-o and not a C4. 2400 would be a great stall. Give you a little better off the line performance. Mikes66 is right that there are two different convertors though. Early versus late.... I can't remember the whole thing. I ran about that in my car before I switched to the C6. If you run mostly in town I would do it....if it fits.
64 Galaxie 500 XL (constantly morphing)
FE 431 Stroker, C-6, Comp/Crane Roller assembly, FPA headers, Edelbrock heads, Zex n2o, Hydroboost.
05-08-2008, 06:40 AM
Mikes66
I am pretty sure the only differance bewteen a C4 and a Cruise-o is the shifting pattern of the valve body, since I own both kinds, and have been inside of both of them.
[SIGPIC][/SIGPIC]
05-08-2008, 08:57 AM
468hmmr
Thanks for the 411. I'll check into that.
05-08-2008, 01:42 PM
468hmmr
He said his transmission was an early one with no vacuum. Mines the original in my `65. How do I tell the difference and will this converter work in my tranny?
05-09-2008, 06:44 AM
fakesnake
That's my stall converter on ebay. I don't recall Broader Performance ever asking for spline size when I bought it. I don't have any technical knowledge about it other than stall speed.
http://www.fakesnake.com
1960 Ford Starliner
1960 Ford Sunliner
1961 Ford 2 door Ranch Wagon
1962 Mercury Commuter Wagon (for sale)
05-09-2008, 11:25 AM
468hmmr
Fakesnake, I sent you a PM.
05-10-2008, 12:12 AM
#9 (permalink)
Bumblebee
I believe pre 66 had a 24 spline with a slightly smaller shaft... 66 and later had the 26 spline imput shaft. I may be off on the dates.....
Keith/Bumble
Coming soon to a mid GA Blacktop 65 Galaxie LTD 2D Fastback Rescued Kudzu Queen 99 5.0, 93 GT40 Heads P&P'd, 8.7:1 hyper slugs,E303 Roller Cam, 1.6:1 roller rockers, Edelbrock performer intake, Holley 600, Shortie Headers.
05-10-2008, 12:29 PM
#10 (permalink)
468hmmr
Thanks Bumblebee. Can anyone confirm this?
