05-08-2008, 02:06 PM   #1 (permalink)
mikhett
holley carb question
On my 62 galaxie 390 9.6 to1 comp crane 901 cam fpa long tube headers im having a problem with a bog on accelaration from a stop. The acell pump cam is amber and its in the no1 hole. I have a holley 600 cfm 1850 list carb. This is a man choke model with the choke not hooked up. When i look down the carb and work the throttle i dont see any fuel but yet i can hit the pedal when on the road and it takes off so i know the acell pump is working. Also when the pedal is all the way to the floor the throttle blades arent at 90 degrees to vertical there more like 75 degrees. Is this right? Thanks
mikhett is offline   Reply With Quote
05-08-2008, 04:10 PM   #2 (permalink)
Re: holley carb question
not enough pull on the cables could be an issue of throttle cable location.
Slight bog is likely Acc pump adjustment.
05-08-2008, 04:10 PM   #3 (permalink)
bluesky636
As far as the throttle blade angle, you need to adjust your throttle rod to the carb. I had the same problem when I swapped out my Autolite for a 625 cfm Road Demon with a custom throttle rod. I had to have my wife sit in the car with her foot on the pedal to the floor so I could adjust the lever. Regarding the choke, I hope you at least have the choke plate either removed or wired fully open? You should see fuel shoot out when you work the linkage. Not sure what to tell you about that.
Bill Haegele
http://www.bills1964galaxie500.com
http://www.novaccc.org
http://local.aaca.org/bullrun/
bluesky636 is offline   Reply With Quote
05-09-2008, 05:14 AM   #4 (permalink)
danv
Slight bog from idle could mean you need to advance the timing a little bit.
2003 Falcon BA XR8 Ute.
1972 Falcon XA GT.
1970 Galaxie 500 Sportsroof.
danv is offline   Reply With Quote
05-09-2008, 05:24 AM   #5 (permalink)
KULTULZ
Post Re: holley carb question
...im having a problem with a bog on accelaration from a stop. The acell pump cam is amber and its in the no1 hole. I have a holley 600 cfm 1850 list carb. This is a man choke model with the choke not hooked up. When i look down the carb and work the throttle i dont see any fuel but yet i can hit the pedal when on the road and it takes off so i know the acell pump is working.
The accelerator pump needs to be adjusted correctly, especially with an inoperative choke.
[FONT=Century Gothic][/FONT]
Carb question? Holley 850 Center Squirter morgan All Ford Techboard 2 03-22-2007 08:49 AM
Holley Carb Question rancheroo All Ford Techboard 4 09-07-2005 05:13 AM
Holley carb question Paul78Zephyr All Ford Techboard 6 07-20-2005 05:10 PM
Holley carb parts swapping question for the gurus kywookie All Ford Techboard 5 08-24-2004 09:41 AM
Holley Carb. Question Gregg All Ford Techboard 3 01-26-2002 01:36 PM
