05-20-2008, 06:04 AM   #1 (permalink)
Whayasay
A few questions...
Morning all,
My 65 Galaxie has a slight miss on idle. It's worse when it's cold. I've replaced the plugs, wires, distributor and rotor. I also had to have a new carb installed. I went with a Holley 750 mainly because the guy gave me a good deal on it. So, what else should I check? Points? Coil? How hard is it to upgrade to a pertronix and get rid of the points? would that help?
How many quarts of oil does the 390 require.
I would like to put a clutched fan on the engine. Will the fan from any big-block Ford work? I imagine I would have better luck finding one from a later model. Or can someone recommend a salvaged e-fan that I could make work? I have a Buick Regal with dual fans, and thought something like that might work, but it's about 4" too wide.
More questions to come...i'm sure.
Bryan
Whayasay is offline   Reply With Quote
05-20-2008, 06:29 AM   #2 (permalink)
Dave66Galaxie
Re: A few questions...
Hi Bryan. You may need points cleaned or adjusted or replaced. Check distributor shaft for side to side play. If the miss persisits, check compression. Also double check your firing order, make sure the plug wires are on right. Pertronix ignition is a great upgrade and easy to install. Mine took about 45 minutes, and the distributor stayed in the motor while I did it. Your 390 holds 5 quarts of oil with a filter replacement.
Hope this helps. Dave
Dave66Galaxie is offline   Reply With Quote
05-21-2008, 08:12 AM   #3 (permalink)
Whayasay
Thanks for the info. I messed around some last night with the points and now the car won't start. It will fire then die. I assume I screwed up something with the points. I'm going to Advance at lunch today to get new points and condenser. How do they install? do you have to gap them? How?
thanks,
Bryan
05-21-2008, 09:41 AM   #4 (permalink)
joedphil
Hey Bryan: If you are going to Advance auto, they sell points conversion kits like Accell which install pretty easy and are the same as Pertronix. I suggest this because it would take the same amount to swap as it would to figure out how to gap replacement points
Joe Phillips
Hell Bent For Leather, Giggity Giggity
joedphil is offline   Reply With Quote
05-21-2008, 02:56 PM   #5 (permalink)
Dave66Galaxie
I agree with joedphil. Turn that junk into a memory. Just be sure to check the distributor shaft for side to side play. Points suck.
05-21-2008, 03:59 PM   #6 (permalink)
deadhorse
points dont suck-- if you guys would learn how to adjust them and your vacum advance--set total timing -- they work just fine --andyour valves will float befor you run out of distribtor
66 galaxie -289 - C4
66 galaxie 352 -some dam trans that looks like a fx -but im not sure
deadhorse is offline   Reply With Quote
05-21-2008, 04:09 PM   #7 (permalink)
DH is right!
05-22-2008, 04:50 AM   #8 (permalink)
Dave66Galaxie
Thumbs up Re: A few questions...
Stolen from a Mopar site:
Point/condenser types of ignitions have been around for more than a half century and while they have progressed to where they are considered reliable, they have some definite drawbacks.
First of all, they require regular maintenance. By 10,000 miles a set of points is shot whether the car is running or not. The pivot and bushing wear so the movable points rattle around, especially at higher RPM's. The contact surfaces wear and become pitted and no longer conduct current well. The springs become weak and don't close the points as fast, and the rubbing block wears off and the gap closes up. The correct way to set points is not by their air gap when open but the degrees of dwell (the amount of time the points are closed). To get the correct setting requires the use of a dwell meter. But still this setting can change after only a few hundred miles of driving.
In 1973 Chrysler replaced the points type ignition with an "electronic" type. Instead of points opening and closing to complete a circuit, it features a stationary contact which passes current to a rotating reluctor, set at a fixed distance. Since this system has no contacting parts, an electric current is a constant amount on each pulse, and can be much hotter, for more complete burning of fuel. Since there is no point bounce and no parts to wear out, it not only gives a hotter constant spark, but also eliminates almost all maintenance. It also offers increased secondary voltage and current for improved starting and will keep the spark plugs cleaner and give greater plug mileage as well as increased performance throughout the whole RPM range. AND YOU WON'T HAVE TO CHANGE POINTS ANY MORE.
Make mine electronic please.
05-22-2008, 05:07 AM   #9 (permalink)
joedphil
Points are fine, as long as they are maintained. My 'point' (hehe) was it would be just as quick to put in a point replacement kit, as it would be to figure out how to adjust the contact points. I myself wanna get the Mallory kit very soon. My LTD does need new points but I want to try the kit.
Joe Phillips
05-22-2008, 05:12 AM   #10 (permalink)
Whayasay
Thanks for all the information. I do plan on eventually converting to electronic ignition eventually, but for the time being (to get the car running) I went back with points and condenser. The car smoothed out quite a bit, but it still has a little "pop" in the exhaust every so often when idling. It will eventually need a new top-end so I will replace everything new then.
Bryan
460 Questions 61gixietoy All Ford Techboard 8 12-26-2006 10:26 AM
\'75 questions. Ranchero66 Torino Pages 0 11-30-2006 07:57 PM
289>347 questions Ahti Stroker Engines 7 02-12-2005 04:54 PM
T5 Questions abagoz All Ford Techboard 2 06-03-2004 10:29 AM
T5 Questions jeffstar All Ford Techboard 2 02-12-2004 08:17 AM
Holley
