06-18-2008, 11:29 AM   #1 (permalink)
valentineday
Question 352 smoking
rebuilt last summer 352 smoking out right duel exhaust
getting worse. the motor shop said to put 2500 miles on the motor for break in, we've put around 1200.
any ideas what we should try.
valentineday is offline   Reply With Quote
06-18-2008, 12:13 PM   #2 (permalink)
ShotRod64
Re: 352 smoking
maybe they didn't get something right.
Did you install the engine or did they? Was wondering if the pcv setup wasn't hooked up correctly. Not sure if that would cause smoking or even smoking from just one side.
Valve seal? Rings not seating properly? You could try some STP or something of that nature and see if it stops the smoking. Check your plugs on that side to see if any are oily so you know which cylinder it is.
That's just some ideas. Someone here might have better ideas of things to check.
Have you called the shop that rebuilt it and asked them? That would be the first thing i would do since they rebuilt it and it doesn't have many miles.
Deb
06-18-2008, 04:14 PM   #3 (permalink)
valentineday
Re: 352 smoking
I called the guy and he won't help. I had some trouble with him during and after he finished the motor. I will check the plugs for oil. Thanks
06-18-2008, 05:16 PM   #4 (permalink)
64GalaxieHTOP
Re: 352 smoking
Does it have a pcv on it or a road draft system? My 352 has blow by that pours out the side of the car from the road draft tube when i am at a light or so. It is all original though.
64GalaxieHTOP is offline   Reply With Quote
06-18-2008, 05:44 PM   #5 (permalink)
deadhorse
Re: 352 smoking
sounds like a broken piston ring-- --or one that didnt seat well--
take off oil fill cover -- does smoke come out where you put in oil??--
66 galaxie 352 -
deadhorse is offline   Reply With Quote
06-18-2008, 06:10 PM   #6 (permalink)
Gordo
Re: 352 smoking
I had one side smoking and it turned out to be a bad float in the carb. Fuel was spilling out into one side of the manifold.
Black smoke = fuel. White smoke = steam/water Blue smoke = oil
Gordo is offline   Reply With Quote
06-18-2008, 07:13 PM   #7 (permalink)
valentineday
Re: 352 smoking
Thanks for the info
The smoke is blue so I am going to check the plugs. I'll let ya know
06-18-2008, 07:19 PM   #8 (permalink)
ShotRod64
Re: 352 smoking
and it is one of them $!#@%!# holleys. ROFL Sorry I just can't help myself.
06-18-2008, 08:02 PM   #9 (permalink)
galaxie
Re: 352 smoking
Who built it? Some people dont double check ****. I have a friend that had a motor put togheter and the rings where to big. Over heated and broke some rings.
Maybe a ring or a wrist pin let go and is tearing up a cylinder?
59,60,64,66,68 Full size fords
87,93 5.0 Mustangs
05 Lincoln LS8
WTB: 1960 Ford Wagon
Pittsburgh PA
galaxie is offline   Reply With Quote
06-18-2008, 08:03 PM   #10 (permalink)
galaxie
Re: 352 smoking
Ha ha.... I love seeing that in my 59 332 car. Just some smoke from under one side.
87,93 5.0 Mustangs
05 Lincoln LS8
Pittsburgh PA
smoking 351 markfive All Ford Techboard 6 08-10-2007 07:41 AM
smoking ujt389 All Ford Techboard 5 04-30-2005 03:49 AM
What has THIS guy been smoking??? deleted2 The Garage 7 11-22-2004 07:55 PM
What is this guy smoking? tim1859 The Garage 10 02-03-2004 12:31 PM
car smoking, what to do [please help!!] roler All Ford Techboard 5 01-15-2002 08:25 PM
