06-23-2008, 07:11 PM   #1 (permalink)
galaxiejohn
Fan spacer
I put the radiatior in the galaxie (63.5 with 390) tonight and noticed that the fan was very close to the radiator. After looking a little longer I seen that the fan was actually hitting the long support rod that runs from the top to the bottom of the radiator. It has a 2 inch fan spacer on it now, I was just wondering what you guys are running for spacers?
galaxiejohn is offline   Reply With Quote
06-23-2008, 07:20 PM   #2 (permalink)
dazecars
Re: Fan spacer
You want at least .5" between the radiator and the fan. If you have a fan shroud you need to center the blades on the lip of the shroud
Galaxie & F S Ford Forum http://www.galaxieforum.com
06-23-2008, 09:02 PM   #3 (permalink)
63ford406
Re: Fan spacer
The orginal spacer was about 1/2" to 3/4". I'll check one at the shop tomorrow.
Ford Galaxie Club of America #665
So-Cal Galaxies
63ford406 is offline   Reply With Quote
06-24-2008, 05:35 PM   #4 (permalink)
63ford406
Re: Fan spacer
I checked today. The orginal spacer was 1". That was all big blocks without a fan clutch.
So-Cal Galaxies
06-24-2008, 06:54 PM   #5 (permalink)
galaxiejohn
Re: Fan spacer
Thanks!! I will go find one tomorrow.
cam spacer? boss302isback All Ford Techboard 2 04-15-2007 08:18 AM
What carb. spacer rfran All Ford Techboard 7 03-15-2006 01:13 PM
carb spacer??? to use or not to use KidPoboy All Ford Techboard 7 11-17-2003 01:09 AM
Carb spacer daveguy3 All Ford Techboard 4 09-19-2003 09:01 PM
cam spacer etp20 Galaxie Pages 2 04-17-2003 09:18 PM
