06-27-2008, 02:48 AM   #1 (permalink)
cgodshall
OPtions from Other Years swap over?
Group
anyone know if options like(tilt, power windows, power seat etc) will swap from 69-70 lincolns, into a 71 Galaxie? ANyone have wiring diagrams for these years?
Or how about 69-70 thunderbird parts swapping over to 71 gal?
cgodshall is offline   Reply With Quote
06-27-2008, 06:15 AM   #2 (permalink)
WUWU20
Re: OPtions from Other Years swap over?
I was told at one time that they won't (steering colume) but I don't know that to be 100% true.
1970 LTD 2dr ht...351W
1996 Thunderbird 4.6
sniff, sniff.....who did that?
www.myspace.com/wuwu20
WUWU20 is offline   Reply With Quote
06-27-2008, 07:11 AM   #3 (permalink)
cgodshall
Thanks.. I wish my hollander Books did steering columns...
I'll keep looking..
06-27-2008, 12:17 PM   #4 (permalink)
ShotRod64
For wiring diagrams you can check the old car manual project. Can't find my bookmark but think it's tocmp.com or tocp.com
06-27-2008, 01:48 PM   #5 (permalink)
dazecars
Originally Posted by cgodshall View Post
Group
Can they be installed, yes, is it a direct swap, probably not. As far as the column you can probably do it but you will need to "modify" things to get it to fit properly. I installed a 66 Mustang steering column ion my 62 Galaxie and it took a little modification to get it to work. I have also seen modern fox, body columns used in classic Mustangs, and aging took modifications. As far as wiring in electrical what you need to do is get a wiring diagram for your car and a wiring diagram for the parts car, then compare and draw up a new diagram for your modification. There again thats what I did when I installed the Mustang column in my Galaxie to hook up the turn signal switch and horn, and that is what I did when I figured out how to install cruse control from a Granada in my 62. (have it figured out but not installed yet)
68 4-lug options, please? Zam727 Mustang Pages (1965-1973) 2 04-18-2007 06:38 PM
Need some help with 289 options frdnut All Ford Techboard 12 06-24-2005 12:13 AM
65 f100 disc brake swap, what years will fit? gtnrb71 All Ford Techboard 1 05-06-2005 02:13 AM
Work 2 years, and get 4 years worth of tuition for free?? MightyMach The Garage 0 05-26-2004 08:05 PM
AOD Other Options IsoRivolta All Ford Techboard 1 12-11-2003 07:32 AM
