Originally Posted by UTRY
Shotrod, I am just answering the question in the first post, not knowing if he has a big or small block, there are two different answers.
1. If the starter drive stays engaged on a small block after an attempt is made to start it, then it is not normal
2. If the starter drive stays engaged on a big block after an attempt has been made to start it, then it is normal and I was trying to explain the difference and the only thing hitting it with a hammer will do is make noise. I don't want to see him replace the starter when it is performing as designed.
Either small block or big block I don't believe the problem is the starter, just getting voltage to it.
I wasn't meaning for it to sound like I was jumping down anybody's throat or anything. Was just wondering why, in most forums, the major or semi major things are mentioned first. I do understand your post and now he has all the info in case it isn't just a wire and what his next move should be.
If it is just a connection, I sure hope his memory is better than mine and if it happens down the road and it's the starter instead! I'd remember that someone said do this or that but most likely wouldn't remember just what that was.
I was chilled then and chilled now.
Well except I HATE side mouse buttons! Twice i've hit that button and went back and lost everything i typed, including the first reply to this!
