Originally Posted by tyrusraymond
I don't know if you've seen the thread that I just started, but I'm trying to replace the worn air shocks on my '63. You mentioned that you put a set of Monroe Air-Max MA 709's on your '64... According to the guy at Monroe these shocks fit a Granada, but he has nothing on '62 - '64 Galaxies. Where did you get your shocks installed and how did they determine the correct model number?
Hey Tyrus,
Some years ago, Goodyear had (and possibly still has) a line of shock absorbers for even the 1964 Galaxie "P" Code (which shock is DIFFERENT from a Standard Galaxie) called Goodyear "Classics". You might see if they still make those items.
BTW, the difference in the "P" Code and the Standard Galaxie, is that the Standard has a pin on one end, and an eye on the other. The "P" Code shock is EXACTLY the opposite. have an eye on one end, and a pin on the other. And you can't just install a Standard shock "up-side-down" because water collects in it.
HTH
JC
