07-09-2008, 05:23 PM   #1 (permalink)
dziner55
1966 Ford 428 Identification
Is it a correct assumption to say that original 428 V8's can be identified by a hand welded "A" on the block? Do all of the old 66 and 67 blocks have this? I know the standard 428 and CJ blocks are different, and I had heard that the Cobrajets had a "C" and the standards all had an "A".
well..........is it?
dziner55 is offline   Reply With Quote
07-09-2008, 06:57 PM   #2 (permalink)
Re: 1966 Ford 428 Identification
no.
Almost every FE block is identical on the outside....
07-09-2008, 07:12 PM   #3 (permalink)
one37tudor
Most but not all standard 428 blocks have the A or upside down V but some of the early ones did not have this marking. Some CJ motors had the C some had the V or A and the same with the police blocks.
Only positive way is to measure. You can also remove the center freeze plugs and see if there is a 428 stamped on the inside. But again most but not all would have this marking. My 66 428 came out of a TBird and is has the upside V marking but nothing else that would identify it.
Scott...
07-09-2008, 07:20 PM   #4 (permalink)
Good stuff Scott!
I'll use that next time I go engine hunting at pick & pull
07-09-2008, 07:26 PM   #5 (permalink)
dziner55
Scott, Mine had the rough welded A. It was not part of the casting, just a rough hand done job, where the flexplate goes.
Vince
I got my info from:
Engine Information
hit "engine identification"
1966 Ford galaxie forddude Vehicles for Sale 0 01-22-2008 12:56 PM
Ford T10 identification, is this from a Galaxie? rusty stuff Galaxie Pages 8 01-19-2008 08:20 AM
Ford seats identification finkster The Garage 2 09-12-2005 08:47 AM
1966 Ford Fairlane 500 XL Nathanl13 Fairlane Pages 1 07-23-2004 09:19 AM
C4 or Ford Trans Identification 69fstbk All Ford Techboard 3 04-07-2003 02:52 PM
