07-15-2008, 09:19 PM   #1 (permalink)
stickshift
what carb jet size do you use for a 352 ?
I am wondering what is a good carb jet size to use on a 62 galaxie with
a 352 auto.? I have a holley 4160 4bblw/elec choke.I have used 57,and
65 jets,yet the engine still misses at hiway speeds and is too lean.
At low idle or full throttle it runs fine.The engine seems to do a
consistent stutter at 60 and occasionally backfires/pops.It appears to
be starving for fuel. The lines and carb are clean and it has a new
fuel pump and filter.Thanks for any help. steve.
stickshift is offline   Reply With Quote
07-15-2008, 09:56 PM   #2 (permalink)
FALCONAROUND
Re: what carb jet size do you use for a 352 ?
try a pair of 72's for git's and shiggles...
Never know what's gonna happen...
When my Gecko is broken, does that mean I have 'A REPTILE' Dysfunction?
07-16-2008, 04:31 AM   #3 (permalink)
64Ragtop
I would change the diafram first it might have a pin hole in it then see if it bogs when the secondares are coming in if so then you probably need a heavier secondary spring because the secondary is coming in too soon.
64Ragtop is offline   Reply With Quote
what size carb?? mart67 Mustang Pages (1965-1973) 5 02-08-2006 06:19 PM
What carb and size to use? scott270r Mustang Pages (1965-1973) 3 01-10-2006 02:06 PM
What size carb for my new set up? 1970coupe All Ford Techboard 4 05-10-2004 09:49 AM
carb size strokerman All Ford Techboard 1 07-20-2003 08:09 PM
Carb size 85mike All Ford Techboard 6 04-06-2002 01:51 PM
