07-23-2008, 02:17 PM   #1 (permalink)
Death Touch
Removing rear package shelf
I need to remove and reinstall the rear package shelf in the '63 boxtop.
I noticed that teh shelf had either warped or poped out of place and is
sitting on top of the rear seat. The only thing I can think of is that it sat
in the sun too long with the trunk closed. It also may not have been
attahced properly.
Any info/directions on what I need to do? Anything I need to watch out for?
Thanks,
63 G code BoxTop 4spd
63 Z code Convertible
63 X code Convertible
63 1/2 Z code 5 spd
70 Dodge Super Bee
Cammer looking for a body
Death Touch is offline   Reply With Quote
07-23-2008, 02:53 PM   #2 (permalink)
ShotRod64
Re: Removing rear package shelf
I dont' know much about them but do be careful when removing as they are just like cardboard basically and will break easy when they are old.
I wonder if after removing you could heat it somehow, like with a hair dryer or something and then weight it down on a flat surface for a couple days. Maybe that would unwarp it? I would say steam but that would just make things worse as far as longevity probably.
What holds those in? Just a trip piece around the the top? Been a long time since I paid any attention to a rear window of an old car. Like since putting a curtain in one...it was the '70s so that was accepted. lol
Deb
07-23-2008, 08:16 PM   #3 (permalink)
63ford406
If it's a non XL it's made out of masonite installed upside down. In the rear it is held down by the window rubber. Up front you will need to remove the rear seat back and then you will see two little brackets that push onto the board and are held to the body with push clips.
Ford Galaxie Club of America #665
So-Cal Galaxies
63ford406 is offline   Reply With Quote
07-24-2008, 11:18 AM   #4 (permalink)
Death Touch
It is an XL.
Thanks for the tips.
63 1/2 Z code 5 spd
70 Dodge Super Bee
custom or off the shelf? cougar All Ford Techboard 12 11-12-2006 11:48 AM
NEED real BAD!! Rear Package tray for a 66 7-litre or XL KenKidd Galaxie Pages 10 05-02-2006 05:58 AM
Oil filter shelf life...... mstngjoe All Ford Techboard 8 04-02-2005 01:08 AM
Does N20 have a shelf life. Nastystang All Ford Techboard 2 06-01-2004 09:18 PM
Any tips for removing rear upper control arm bushings from axle housing? 89Trooper All Ford Techboard 9 02-12-2004 08:43 PM
