07-30-2008, 04:25 PM   #1 (permalink)
exporta
swapping out a 352 for a 390
i need to swap a 352 engine out of a 62 merc which is similar to a galaxie .i will be using the existing automatic transmission. i need to know if a 390 engine is a direct swap or will there be things that have to be altered such as flex plate/convertor, motor mounts as this will probably be a post 1965 engine going in, and accessory mounting holes such as ps pump and generator. any and all help and suggestions would be greatly appreciated. thanks.
exporta is offline   Reply With Quote
07-30-2008, 04:43 PM   #2 (permalink)
CaptVirgilHilts
Re: swapping out a 352 for a 390
You need to watch out for the block castings as I think the later 60's casting changed the way they bolt to the engine mounts. Not sure what year they changed though
Stu
1967 Mustang Coupe
07-30-2008, 05:36 PM   #3 (permalink)
FORD40
The 352-390 are the same block. Should be a bolt in.
leechburg,pa.
FORD40 is offline   Reply With Quote
07-30-2008, 06:40 PM   #4 (permalink)
CaptVirgilHilts
http://www.fordmuscle.com/forums/all...questions.html
Search and ye shall find...
Keep the original water pump as it is specific to genny equipped cars.
Stu
1967 Mustang Coupe
07-30-2008, 06:59 PM   #5 (permalink)
coosbaylumber
If you are installing an Automatic of the 1962 variety, be kind on the foot pressure. We did this to a Ford decades ago, and pooped the transmission after about two months use. Just could not take the extra strain per one fellow.
Not a plop in fit, but are you expecting to use 1962 era starter, generator, electricals?
You may also have to look for correct exhaust manifolds too. The 1962 ought too have vertical bolts, and the 1965 diagonal bolts. They may LOOK like they fit but try em NOW.
Wm.
Old Ford owner
07-30-2008, 07:43 PM   #6 (permalink)
exporta
thanks for taking the time to respond guys !!
07-30-2008, 07:46 PM   #7 (permalink)
exporta
coosbaylumber brought up an interesting point . will the newer style starter fit into the transmission bellhousing?? if not, any suggestions on a solution for that problem or do i just change the trans to a c-6. will that bolt in directly??
07-30-2008, 10:41 PM   #8 (permalink)
63ford406
Motor mounts won't fit. You'll have to make adapter plates to bolt to the block and then the mounts to them. Early blocks only had two motor mount holes. Later blocks (65 and up) had four. Late starter won't fit early flex plate, wrong tooth count. There is a starter drive that's available to make it work. Use the 65 trans, flex plate and starter, it will all fit the 62 engine.
Ford Galaxie Club of America #665
So-Cal Galaxies
63ford406 is offline   Reply With Quote
07-31-2008, 03:39 PM   #9 (permalink)
CaptVirgilHilts
I think he said he's probably getting a newer motor and installing it in the '62 not the other way around.
Stu
1967 Mustang Coupe
07-31-2008, 07:17 PM   #10 (permalink)
coosbaylumber
I think motor mounts will indeedy fit. The side to the engines past 1965, (including the 427's, used to have four stud bosses sticking out. The modern engine mounts used three of the holes, and the earlier ones used two of the holes. You must use the early style mounts, not those of 1965 or later then.
It works. I done it decades ago.
Big problem we had was instead of looking for and purchasing later model exhausts, we went and used earlier heads on the more modern block, to save us the time and expense of the searching.
Wm.
Old Ford owner
swapping 3 spd to C4 9t3lightning Galaxie Pages 3 10-13-2007 06:10 AM
swapping out a 4.6L to 5.0L 1965VR All Ford Techboard 8 06-19-2006 11:04 AM
Swapping: 400 to 302 xpauliber Truck Forum 3 12-05-2005 01:55 PM
Swapping to a V-8 Neil74 All Ford Techboard 1 08-18-2004 10:11 AM
swapping a toploader to a T5 zICRONIx All Ford Techboard 0 05-26-2002 04:48 PM
