i believe the one thats giving me the most trouble is the head light switch? its the knob right next to the ignition switch. looks like the fuse box/pannel is part of it.
Not sure on your year but on a '64 you reach up behind there at the switch and find a little button you can push down and you can then pull the light switch knob and stem out. They you are able to remove the bezel by unscrewing. Yours might not be the same though.
Oh the little button is on top of the switch behind the dash there. I just had to feel around til I found something that would push down. Hope it's the same on yours. I also think it's another use a screwdriver, needle nose pliars etc to loosen the bezel.
Deb
