Originally Posted by fakesnake
I noticed that in the rear one side is 1/2" lower than the other side. Do I have to replace or can you repair? I am not familiar with rear leaf springs, do you just add another piece in to raise it up if repairing?
Seriously?
I would suggest measuring (on level ground), from the same point on the frame from a point in front of spring at the front spring mount and at the rear spring hanger and finally at some where near the bumper support.
Bumpers do require alignment they can be moved a little. You did mention that you measured where the wheel well hit the wheel/tire. Just for grins, since you will be doing the work not me
, try swapping the rear tires side to side, see if the problem carries over with the wheels or evens out. Before chasing a spring issue, I'd try to make sure that nothing else is wrong. It might even be that the rear frame which is kind of weak is slightly tweaked, an alignment shop has jacks that can help there. Re-arching springs - for a 1/2 inch difference, seems like trimming your moustach or eyebrows.... a little here, then a little there - pretty soon nothing is right.
by the way...they do make wedges that racers use to change/adjust pinion angles. You loosen the bolts that go over the axels, slide the wedges in and tighten the bolts again. Low riders use blocks to raise the axel, by dropping the spring....there has to be something yu can do to get 1/2 inch, without bending the spring, after all, its just a 1/2in.
