Originally Posted by 63forme
Can anyone out there help? I'm in the proccess of doing a body-off restomod and I can't remember for the life of me how to route the fuel line. I got a pre-bent line from classic tube as a gift but it just doesn't seam correct and they can't help me?????????????????
I just replaced mine...body on, and it was an absolute bear. I got one from Classic Tube and it was bent to replace the factory alignment and bend points...along with a few "shipping bends." It was actually pretty close to right on. I swore often that "if only the body was off!!" This line was meant to be installed prior to the body going on, so you have the best shot at getting this right. From the fuel tank, the line generally heads toward the driver's side, crosses over top of the frame ahead of the rear axle to a position on the outboard side of the frame. Once it gets up to front of the front door, it transitions atop the frame again and winds around the steering column and ends up about mid-engine ready for that last rubber hose to the fuel pump. The line attaches at intervals with special clips that also support the brake line. Look on the driver's side outboard frame and see if you can find the clips I'm talking about. If they're still there, they're your guide to getting this line back where it belongs.
