09-30-2008, 08:56 AM   #1 (permalink)
66_galaxie5
Master cylinder replacement
Since I started to work on the brakes for my galaxie, should I also replace the master cylinder? I do not have a brake booster, should I buy a booster for my car while I am at it?
I am not sure if it will work since I do not know where the vacuum hose would go..
I have drum all around
thanks...........
1966 Galaxie 500
289-2V
FX Cruise-O-Matic 3-speed
3.00:1 non-locking
66_galaxie5 is offline   Reply With Quote
09-30-2008, 08:58 AM   #2 (permalink)
ShotRod64
Re: Master cylinder replacement
If you don't have power brakes already i wouldn't bother with a booster. As for the master cylinder, you could get a new one or you could just wait if it's not leaking and seems to be working well.
Napa and Kragan have a rebuilt MC for like $30 and probably Autozone does also as most of the time they all sell the same one at a dollar or two difference.
09-30-2008, 09:38 AM   #3 (permalink)
Rich27028
if you replace the master-- get one for a 1967 its two chambers --and split the lines to the front and back brakes--
drums all around
66 galaxie 352 -PS-PB-
Rich27028 is offline   Reply With Quote
09-30-2008, 01:35 PM   #4 (permalink)
66_galaxie5
drums all around
So I can ask for a 1967 galaxie500 master(non booster) and just put that puppy in my 66?
I do not have to bend the lines or anything like that?
What does splitting the lines do for the car?
thanks,
Ac
1966 Galaxie 500
289-2V
3.00:1 non-locking
09-30-2008, 02:04 PM   #5 (permalink)
ShotRod64
You run the rear brakes to one reservoir of the MC and the front brakes to the other reservoir. I believe the larger of the 2 reservoirs is for the front brakes. This is so if you have a wheel cylinder go out or some other reason for a leak you are only losing the brakes that that line is connected to and it only drains the one reservoir. Unlike the single that you have. You have a fluid leak you lose everything.
I think you will only need a splitter so that you can continue 2 seperate lines to the MC.
10-03-2008, 06:11 AM   #6 (permalink)
66_galaxie5
thanks for the info...I think I will wait for it to leak before I replace it with a 67 gal MC.
1966 Galaxie 500
289-2V
3.00:1 non-locking
Master Cylinder Replacement psivory Galaxie Pages 22 03-24-2006 07:05 AM
which master cylinder do i use volkstony Galaxie Pages 3 07-16-2005 12:27 AM
Master cylinder 351bolt All Ford Techboard 6 04-08-2005 12:27 AM
Bleeding the brakes on a 64/swapping out master cylinder with a dual master cylinder norcal500 Galaxie Pages 8 10-03-2004 01:07 AM
Is it my Master Cylinder or Wheel Cylinder? andysam All Ford Techboard 3 07-15-2003 01:30 AM
