09-30-2008, 09:11 PM   #1 (permalink)
v8shadow
65 galaxie drum to disc coversion question
Using the spindles off a 79 Cougar, and tie rod ends from a 70 LTD. I have measured the positon of the tie rod end assembled with a stock spindle. Will the position in the adjusting sleeve be the same using the 79 Cougar spindle? I plan on getting it close, then taking it to a garage to be put on an alignment machine, to get it right. What alignment adjustments are on the 65 anyway?
KEN
Factory 65 Galaxie 500 390/4v
v8shadow is offline   Reply With Quote
09-30-2008, 09:20 PM   #2 (permalink)
Domino
Re: 65 galaxie drum to disc coversion question
It will be very close. You could always measure from center to center on the tires and adjust if necessary. The alignment shop will adjust caster, camber and toe as needed. This might help understand. Wheel Alignment A Short Course
Domino is offline   Reply With Quote
another drum to disc question oneputtster Galaxie Pages 10 07-27-2008 01:37 PM
63 Galaxie Drum to Disc Front Brakes radioactiveman Galaxie Pages 5 08-30-2007 03:51 AM
Disc brake coversion options? velomech Fairlane Pages 3 11-24-2006 03:49 PM
5 speed coversion question... vinnietbird Late Model EFI Techboard 8 02-20-2006 02:18 PM
Pics of Drum Brake to Disc Brake Conversion on 1967 Galaxie. 1967xlfastbackgalaxie Galaxie Pages 11 01-08-2004 01:50 PM
