02-16-2009, 07:11 PM   #1 (permalink)
kimura97
18" wheels
i have looked though the forum and i cant seem to find what offset i need for the rims im looking for. i want some 18s for my 64 galaxie but i cant find the right offset. and just for reference would you happen to know for 20s?
thanks guys
kimura97 is offline   Reply With Quote
02-16-2009, 07:22 PM   #2 (permalink)
galaxie
Re: 18" wheels
thanks guys
Im not 100% sure but I had a 66 vert with Mustang 17" wheels. I looked like 1.5" in the front and nothing needed on the rear.
Just for ****s and giggles I lined up my 18" black bullit wheels on my 64 Galaxie... SWEET!
59,60,64,65,66 Galaxies Y-blocks to FE Strokers
87, 93 Mustangs Stock & 331
Pittsburgh PA
http://threerivers.galaxieclub.com/
galaxie is offline   Reply With Quote
02-16-2009, 07:27 PM   #3 (permalink)
kimura97
Re: 18" wheels
yeah i love black wheels. but i think i have to go with the boss 338s in chrome. im loving them and they are cheap. i just need to make sure i got the right wheels though, thanks man. are you pretty sure or are you kinda ifffy?
02-16-2009, 07:34 PM   #4 (permalink)
danv
Re: 18" wheels
Try this as a guide.
Ford - Vehicle Bolt Pattern Reference
2003 Falcon BA XR8 Ute.
1972 Falcon XA GT.
1970 Galaxie 500 Sportsroof.
1963 1/2 Galaxie 500 Fastback.
danv is offline   Reply With Quote
02-16-2009, 08:19 PM   #5 (permalink)
kimura97
Re: 18" wheels
Originally Posted by danv View Post
yeah i know the bolt pattern and stuff, would you happen to know the offset?
02-16-2009, 08:26 PM   #6 (permalink)
danv
Re: 18" wheels
The offset is listed there!
It says typically zero offset.
1972 Falcon XA GT.
02-16-2009, 08:57 PM   #7 (permalink)
gbeeler
Re: 18" wheels
I have no clue on offset. Everything I've ever ordered was based on back spacing. I run 8" wide in the rear with 4.25" back spacing. Front I am running 7" wheel with 4.75" back spacing on the hard top and 7" wheel with 4.25 back spacing on the vert. In all actuallity the wheel size doesn't matter since the tire gets smaller as the rim gets larger so you are esentially running the same or close to the same overall heighth. My vert sits a little higher than the hardtop so I didn't need as much back spacing on it. With a 2" drop on all four corners the car sits low and you have to worry about the tire contacting the fender lip when you turn sharp and or hit a bump while turning.
Just my 2 cents worth of experience and isn't much, I'll give you better advice after the Obama administration has stimulated me to 2.02 cents worth of knowledge.
64 Galaxie 500 XL Hardtop (constantly morphing)
FE 431 Stroker, C-6
64 Galaxie 514 XL Convertible (WIP)
514 Stroker, AOD
gbeeler is offline   Reply With Quote
02-16-2009, 10:16 PM   #8 (permalink)
esnola25
Re: 18" wheels
the boss 338's will fit here is a pic of a 64 gal with some... i am thinking of getting the same wheels for my gal
esnola25 is offline   Reply With Quote
03-28-2009, 07:26 PM   #9 (permalink)
orb57
Re: 18" wheels
Did anyone come up with conclusive statistics on the Galaxie backspacing issue. I am considering Boss 338's for my 60 Starliner. Here is a list of possible sizes. I am hoping for 20's in back and 18's in front. With and backspacing are the unknown variables. Any ideas?
BOSS Wheels - BOSS 338
orb57 is offline   Reply With Quote
03-28-2009, 09:33 PM   #10 (permalink)
fakesnake
Re: 18" wheels
On your Starliner you can run 20x8 1/2" in rear with 4 1/2" backspacing. If you dump car in back or run airbags it will hit on the top of wheel well when you lower car. A 4 1/4" backspacing will give you a smaller wheel lip but center the wheel a little more when lowered.
In the front you can run 18x8 with 4 1/2" backspacing with no problems. I would go 245/45/18 on the front tires.
http://www.fakesnake.com
1960 Ford Starliner
1961 Ford 2 door Ranch Wagon
1962 Mercury Monterey Convertible
fakesnake is offline   Reply With Quote
17" wheels for Vintage Mustangs MY TWO STANGS All Ford Techboard 7 11-23-2008 07:41 AM
wheels for 5/8" studs bonfire All Ford Techboard 4 08-14-2008 05:35 PM
Looking for four 15" wide steel wheels, 6 or 7" wide. ling102 Wanted 3 02-05-2008 06:38 PM
Probe Industries
