05-18-2009, 12:23 PM   #1 (permalink)
gentz
1962 galaxie 500 neutral/reverse switch.
Hello guys back here looking for parts. Any one have a safety neutral/ reverse switch or know where i can get one for my 1962 galaxie 500? thanks.
gentz is offline   Reply With Quote
05-18-2009, 08:02 PM   #2 (permalink)
ShotRod64
Re: 1962 galaxie 500 neutral/reverse switch.
Moved the power steering replies to the correct thread.
As for the NS switch, if they don't have them at Napa have you checked Dearborn Classics or Macs? There is also this place.
Ford Parts at C&G for 1932 thru 1979 Ford car and Ford truck.
You can check out some of the links here also. Rock auto is another place to check. Addresses are listed on site below.
Related Links
05-18-2009, 09:02 PM   #3 (permalink)
gentz
yea seems no one has it listed, i guess i will get to work and see if i can revive it..
05-18-2009, 09:03 PM   #4 (permalink)
stickshift
If you have the fordomatic 2 spd then the part # is C1AA-7A427-A ,and if it"s a cruise-o then it's C1AA-7A247-B. They have been on ebay for around $15 to 35$. It is the same switch for the 61 or 62 galaxies. Or cheaper still, just pull the old wires from the switch and the car will still start, although now it will start in any gear, so be aware of that.
www.galaxieclub.ca
stickshift is offline   Reply With Quote
05-18-2009, 09:07 PM   #5 (permalink)
stickshift
I have tried to repair my old switch, but the problem is that the groove that the little ball bearing goes thru gets worn over the years with all the starts. Then it has a hard time to complete the electrical circuit and this is why often you have to wiggle the shifter arm back and forth to get the car to start.
www.galaxieclub.ca
05-18-2009, 09:07 PM   #6 (permalink)
Domino
I had mine bypassed on my car. You can jump the two wires that are red with blue stripe. I got lucky and my parts car had a good one.
1962 Galaxie 500 2 door sedan(62A) http://www.cardomain.com/ride/3091676
The car is named Albert(Big Al, not Big Gal!) ¨Built not Bought¨
Domino is offline   Reply With Quote
05-18-2009, 09:08 PM   #7 (permalink)
gentz
yea i have it that way right now while i fix the carburator...i just bypassed the wires. im gonna check ebay now.....thanks
05-18-2009, 09:21 PM   #8 (permalink)
Domino
Ebay items:220416839689 and 220416840524.
05-18-2009, 09:23 PM   #9 (permalink)
gentz
heheh out of curosity how do i know which tranny i have? my lever shows a green dot and L
05-18-2009, 09:28 PM   #10 (permalink)
gentz
this is my vin2J64W113005
Having problems neutral/reverse switch Ivy72falcon C4 Transmissions 5 12-02-2008 03:10 PM
64 galaxie :_ HOw to operate neutral safety switch ? kuumakyyticom Galaxie Pages 1 10-22-2007 12:46 PM
Neutral Safety/Reverse Light switch 4camtbird Torino Pages 0 08-10-2006 09:44 PM
early c4 neutral saftey switch, reverse switch location? thetmaxx C4 Transmissions 5 03-13-2006 02:55 AM
Where is the neutral safety switch on a 67 Galaxie?? lnmrmn Galaxie Pages 5 06-03-2005 04:19 AM
Probe Industries
